LED eagle eye lights in dash panel - who did this mod?
Old 08-19-2018, 07:48 PM
TWISTER324's Avatar
TWISTER324
TWISTER324 is offline
Months ago I read a thread on here where one of our members used a set of these in their dash. I can't find the thread anymore so I'm asking for everyone's help. Here is an image of what was used.
Old 08-20-2018, 01:45 AM
mrbigshot's Avatar
mrbigshot
mrbigshot is offline
I just used some led 194's off ebay. not much reason to make it more difficult.
Old 08-20-2018, 09:35 PM
BaltoMoJoe's Avatar
BaltoMoJoe
BaltoMoJoe is offline
LED eagle eye lights ? are these brighter than the LED 194's ?
if not then what makes them better ?
Old 08-21-2018, 05:47 AM
TWISTER324's Avatar
TWISTER324
Yes they are brighter and dimmable.
I just need to ask a question to the member who did this mod.
Old 08-21-2018, 12:26 PM
beartracks's Avatar
beartracks
beartracks is online now
They don't look like the dash light bayonet sockets.
Old 08-21-2018, 12:30 PM
TWISTER324's Avatar
TWISTER324
They are not
Is anyone reading what I'm asking for?
I know what most people are using. I know this is not something most users are using. I'm looking for the user that did this
Old 08-22-2018, 10:37 AM
beartracks's Avatar
beartracks
Well you could be a little clearer. Are you adding them in new holes for something?
Old 08-22-2018, 10:39 AM
TWISTER324's Avatar
TWISTER324
No, I'm using these to light the gauges just like some other user did here
Old 08-22-2018, 12:04 PM
1KILLERZ's Avatar
1KILLERZ
1KILLERZ is offline
I understand you
Unfortunately, I do not know the post you are speaking of.
Old 08-22-2018, 12:29 PM
ranger140892's Avatar
ranger140892
ranger140892 is offline
Twister, I've used them for indicator lights. I wouldn't think it would be too difficult to put them in the instrument cluster. Disassemble the cluster and open bayonet/twist in holes to 1/2". I think it'd be wise to use a rubber washer between the nut and the printed circuit. Then run each LED's hot wire directly to the panel light wire coming off the headlight switch. And run all the ground wires to a common ground screw on the dash support frame. I would use quick disconnects for the ground and hot wires so you can easily remove the cluster in the future.
Old 08-22-2018, 02:51 PM
TWISTER324's Avatar
TWISTER324
Exactly what I was thinking! Thanks Ranger140892!
Old 08-22-2018, 08:26 PM
ranger140892
You're welcome. Good luck!
tonyrosen
2009 - 2014 F150
06-09-2016 09:18 AM
Niwrek
01-15-2016 07:59 AM
Ctkallday666
59
12-14-2012 10:15 PM
Tanner2255
1999 to 2016 Super Duty
29
08-25-2012 06:25 PM
grandpa'sprideandjoy
13
02-09-2010 07:55 AM
Quick Reply: LED eagle eye lights in dash panel - who did this mod?
