89 f250 no start after new distributor
Hi there, I'm hoping for some help in finishing up a distributor install.
I recently had a no start where I was getting fuel but no spark. Then replaced the ignition coil, but got no change so side of the strip place the distributor thinking that the ignition module and stator were probably the problem.
Removed and replaced the distributor as per Hanes instructions, also replaced the #1 and #1 spark plugs, (planning on replacing them all before timing)
when I went to hook the cables back up I found a plug that I can not remember where it came from or if it was hooked up. It is located above the plug for the ignition module and what I believe is the spout.
Also, my spout just dead ends into a cap, do I need to take that apart to properly time the engine?
Thanks in advance for the help, sorry if my lingo is off. I'll post a pic of the wiring harness below.
The SPOUT is removed from the harness to set base timing.
Ok so it will turn over but not start?
1. When you turn the key do you hear the fuel pump?
2. Does it run then shut off or does it keep running?
If it keeps running then your problem is with the PCM you will need to check it for bad Caps. If the fuel pump comes on then quits after a few seconds then you need to check fuel pressure on the rail.
Drew Botts
11-01-2016 05:25 PM
mox-ct
37
08-17-2010 04:15 PM
farmsks
27
06-24-2004 09:48 PM
