I have an 86 F250 with a 302 fuel injected engine. It has no spark. I clamped a spare spark plug to the dip stick bracket and put one of the spark plug wires on it to verify this. I verified the fuel pump attached to the frame below the drivers side firewall does run. I removed the computer but haven't removed it from the wiring harness yet. I replaced the coil. Checked the distributor cap and rotor, they are used but not in bad shape.
My questions are:
Does this truck have an electronic module for the distributor?
I can't seem to find it.
What should I do to diagnose the no spark issue?
Have you tried the module mounted on the distributor? Also check for any codes.
Dave,
Thanks for replying. You'll have to bear with me. I'm a GM guy with occasional Ford trucks, after all they are the strongest, toughest trucks built.
Anyway, module on the distributor? It has a cap and rotor, inside looks like an electric sensor for timing. The coil is mounted forward of the driver's side head on a bracket. What module? I'll try to get a pic.
No, I haven't tried a new one yet. It looks like the one on my distributor. Is there a way to test it??? My Haynes manual is too general and tries to cover too many different styles for me to make any sense out of it. Thanks for the help
Most parts stores can test it for you. IIRC, there are 2 5.5 mm bolts (7/32" equivilent) holding it to the dist. When you get them out (You might have to loosen the dist and rotate it to get the bolts out) Then wiggle it while pulling down, there are 3 prongs that stick straight up to contact the pickup coil connector and sometimes they get brittle.
Thanks for the help. I'm going to call the two places I know do the testing first thing in the AM and go from there. I'll post a solution tomorrow.
New info.
Replaced the TFI module for $41.34. Had to buy a tool that is 7/64 made for removing the TFI module. Had to rotate the distributor to remove the back bolt from the TRI module. After putting the dielectric grease on the back side of the TFI Module, I installed it and reset the distributor to about where it was. Tried to start it and saw a weak spark on my sparkplug that is clamped on the engine for viewing purposes. Plugged in the spark plug wire to it's original plug in the block. The engine seemed to want to run. I squirted some fuel in the intake of the fuel injector air inlet aluminum body and it ran for about 5 seconds. Tried about 5 more times with same results. Now I'm going to dig into the fuel delivery, filter, pumps etc.
Pull the codes. If the computer doesn't see a signal from the module, it won't turn the pumps on. Maybe a wire is broken or loose to the module. The computer has a error code it spits out when it doesn't see a signal from the module.
I don't know how to get the codes. It's a 1986 F250.
