01 have lights on dash and power to windows with key out
Old 06-23-2018, 07:26 PM
Greg Duber Jr's Avatar
Greg Duber Jr
Greg Duber Jr is offline
Have a 01 f150 4.6 crew cab with key out and door closed I have the check engine light on oil light and abs light stay on not bright but bright enough to see and I get power to window switches and switch for my pedals to move up and down it will drain the battery. I replace gem module relays ignition switch interlock solenoid headlight switch everything is stock on truck need help please
Old 06-23-2018, 09:48 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
have you noticed the drivers floor being wet after a rain ? Is it possible the windshield leaks ? There have been some occurances of random electrical problems due to water leaks.
Old 06-23-2018, 10:11 PM
Greg Duber Jr
no and I replaced the gem module
Old 06-24-2018, 10:43 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
All power for the dash comes through the ignition switch.
Is it releasing?
Are leads in the harness to it crossed etc.?
The key tumbler is only the lock, not the switch.
The tumbler operates a rod to the ignition switch down the column.
Check all this out.
Skuvas
01-12-2013 06:44 PM
lostmybeer
08-06-2012 10:06 AM
mark8881
1997 - 2003 F150
10-19-2008 02:10 PM
robert paul
05-26-2008 01:41 PM
H U R L E Y
1978 - 1996 Big Bronco
16
12-25-2006 06:11 PM
Quick Reply: 01 have lights on dash and power to windows with key out
