Front Spring Pack Install Procedures
For those not following quite so closely, Stewart_H posted the link below with detailed information concerning the front springs.
2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds | SuperMotors.net
Update on new front X code springs,they raised truck 1-1/8",the ride seems to be as good or better than old V codes,it seems to not wander as bad on less than perfect roads,that could be due to the new spring bushings ?,time for alighnment it did changed steering wheel position.
https://www.ford-trucks.com/forums/7...with-pics.html
2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds SuperMotors.net
Stewart
There is no need for an alignment if the steering wheel is off. There is a thread that shows you how to adjust it and its very easy.
Dustin_86
01-10-2005 05:51 PM
