Front Spring Pack Install Procedures
Old Jun 15, 2018 | 10:54 AM
crop harvester's Avatar
crop harvester
Any write up's or Videos.
Old Jun 15, 2018 | 01:49 PM
brian42's Avatar
brian42
Veteran: Navy
https://www.ford-trucks.com/forums/1...s-removal.html
Old Jun 15, 2018 | 09:46 PM
crop harvester
Just what I needed,Reps sent.
Old Jun 15, 2018 | 11:44 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
For those not following quite so closely, Stewart_H posted the link below with detailed information concerning the front springs.
2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds | SuperMotors.net
Old Jun 22, 2018 | 10:30 PM
crop harvester
Update on new front X code springs,they raised truck 1-1/8",the ride seems to be as good or better than old V codes,it seems to not wander as bad on less than perfect roads,that could be due to the new spring bushings ?,time for alighnment it did changed steering wheel position.
Old Jun 23, 2018 | 09:17 AM
akcooper9's Avatar
akcooper9
There is no need for an alignment if the steering wheel is off. There is a thread that shows you how to adjust it and its very easy.
https://www.ford-trucks.com/forums/7...with-pics.html
Old Jun 23, 2018 | 02:55 PM
Stewart_H's Avatar
Stewart_H
2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds SuperMotors.net
I prefer to point people to the Excursion Forum Tech Folder and tell them to scroll down to the second post, to the suspension section, where they can click on the several different spring swap how-to's I have listed there because that link you posted has bad directions for part of the swap. It's much easier to remove the front bumper than it is to remove the bumper bracketry, and that link has it wrong in that area, so I usually don't link to that how-to without an advisory to ignore that section and to just remove the 4 bolts holding the bumper on. And actually, getting the front bumper part wrong in that how-to was part of the impetus years ago to create the how-to write-ups, hints, tricks, and advice I put together to help others.
Stewart
Old Jun 24, 2018 | 04:53 PM
crop harvester
Thanks on that info. about steering wheel centering.
Old Jun 25, 2018 | 10:59 AM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by Stewart_H
I prefer to point people to the Excursion Forum Tech Folder...
There's a lot of good stuff in there relevant to our engine and pickup version.
Old Jun 25, 2018 | 05:38 PM
Stewart_H's Avatar
Stewart_H
I'll have the one for this forum up and running too. Just had some personal setbacks the past couple years and haven't had the motivation to dive in and tackle this slow coding process needed to overhaul the one for this forum.
Stewart
Becky_is_a_66
Jan 25, 2014 09:33 PM
Dustin_86
Jan 10, 2005 05:51 PM
