Give me a lift will yah?
Okay i have a quick question about lifters, I have a 78 F100 300, its all stock, Will changing lifters make any difference in the way it performs? i know if the lifters are too much longer than stock it will cause valve to piston connection and will cause major problems. I would like to know if different lifters will change anything. I was on FTE once and someone said you can use chevy 350 lifters on a 300. I dont know if thats true or not please correct me if anything i said was wrong.
I think what you're thinking about is the rocker arms. You can use Chevy 250 (the inline 6) rockers on a 300 for a little extra valve lift (which is comparable to a mild performance cam).
Longer lifters, however, could technically give you more lift (although I think your valves may even be stuck open), but would throw off your valve train geometry and could damage, bind up, or at minimum, prematurely wear out your valve train. Longer lifters is basically like putting in push rods that are too long.
Standard 250 rocker arms are 1.75s. If you have the original '78 300, should be a bolt-on. Remove the valve cover, replace the rockers one at a time, reset gaps, replace the valve cover and retune. Make sure you are not getting any undue interference on the pushrods etc. when you reassemble. Think that covers the normal process... do a search for better detail (always a good idea before asking any question. 95% of the questions on these forums have been repeated multiple times.)
I believe they are 1.73 ratio. What happens is with the higher ratio you are moving the p.rod closer to the fulcrum/pivot point/rocker stud. I used 1.7 rockers for a while and could easily see that my p.rod was uncomfortably close to the side where it passes through the head. And I have the desireable
slot type hole thru head.
I can't help but wonder how wise it is to add more stress to the springs, r.arms, studs, of an engine with many miles on it. Putting on the chebby rockers reminds me of the 'Instant Engine Overhaul' cans they sell in the A.parts stores.
cathode
01-24-2011 01:31 PM
tbm3fan
05-18-2007 01:51 AM
BIG66PROJECT
22
05-06-2006 06:35 PM
dennyjr47
09-03-2004 08:44 PM
