Dash Trim for Double DIN radio install
Anybody got pictures of the trimmed dash for an aftermarket Double DIN radio install? I believe I need ~1/8" more height to get the Joying unit into the cubby hole. But want to see what others have done before I start trimming it. Also, do I need to get the entire dash off the EX to trim? or can this be done with the dash installed?
This is what needs to be trimmed.
A not so great job of trimming, but effective.
My installed Sony. No need to remove the dash. I actually needed to remove the dash after I did the trimming for the USB extension I swapped into the 12v receptacle on the right. Would have made trimming much easier.
If you are going to use the Metra 95-5817 Dash Kit for your radio, Make sure you have everything ready before you fully install your unit. That model is made to lock in place once installed. To remove you will need to disassemble dash. Just FYI as when I installed my unit to test fit it locked and had to remove my dash.
Some people have luck connecting the steering wheel controls and some don't. It has to be done with one of 2 aftermarket adapters. This one is supposed to be the easiest. Good luck
https://www.crutchfield.com/S-mRnuoQ...l-Adapter.html
WB4IUY
08-07-2016 02:06 PM
