Sponsored by: Real Truck
Dash removal?
Old Jan 3, 2006 | 10:00 PM
hink10's Avatar
hink10
Dash removal?
I have an 03 Excursion and need to replace the stock stereo. The clips have been damaged so a removal tool won't work. Anyone know how the dash comes out? Thanks.
Old Jan 3, 2006 | 11:07 PM
99f350sd's Avatar
99f350sd
Yes but doesn't the radio have to come out first to get the dash off..Sounds like you are in a pickle. Some radio shops may be able to help you. They can get anything outa there. If you know how the clips work it gives you an advantage.
Dick
Old Jan 3, 2006 | 11:12 PM
hink10's Avatar
hink10
I thought the radio was attached to the dash and should come out with dash? Does the radio actually mount to metal behind the dash so it has to be removed first?
Old Jan 3, 2006 | 11:38 PM
99f350sd's Avatar
99f350sd
There is two screws behind the radio if its the same as my 99.
Old Jan 4, 2006 | 12:27 AM
RocketScience's Avatar
RocketScience
Rather than start a new thread, I figured I would ask my question in this one, as a search netted only marginal results.
Patient: '01 F250
I've got a light burned-out behind the climate control switches (A/C, Fan, etc.) just below the radio. Is a full front dash removal (as noted in THIS thread) required to do this?
Old Jan 4, 2006 | 09:07 AM
99f350sd's Avatar
99f350sd
Same as above yes. Its called the cluster panel if I remember. The manuals are not easy to follow and I've just pulled the dash off my aerostar so I'm all messed up.
Dick
Old Jan 4, 2006 | 09:59 AM
fireman28's Avatar
fireman28
The answer to both questions is the radio comes out first then there are 2 screws behind the radio to remove and the dash will pull off. The ac controlls are then held in by 4 screws.
Old Jan 4, 2006 | 10:42 AM
hink10's Avatar
hink10
Any Ideas how to get the radio out with damaged clips?
Old Jan 4, 2006 | 10:54 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Hammer-big one!! lol My radio clips are damaged on one side also, So I am going to remove the panty hanger panel under the dash and the cup holders and see if I can get to it that way, Ill post back if I am successful.
Old Jan 4, 2006 | 11:09 AM
fireman28's Avatar
fireman28
I would just take it to a local shop (Not a retail store) and see if they can get it out.
Old Jan 4, 2006 | 11:57 AM
RocketScience
.......then there are 2 screws behind the radio to remove and the dash will pull off......
REALLY???
You mean I gotta remove the WHOLE front dash just to change a measly little light bulb behind the A/C controls???
DANG!!!
Off to that 'Ford engineers that must die' thread......
