Need quick answer, dash removal?
Old Nov 13, 2013 | 05:06 PM
Metalhead47's Avatar
Metalhead47
Not finding anything obvious on a search. First time pulling the dash on my X, as I understand it, all I *should* need to do is remove the radio (already done), then the dash comes out with clips & some yanking, correct?
Its not budging the least (not an inch to the west, not an inch to the east) right now, and I reeeeealy don't want to put any more pressure on it than I have without hearing from someone who actually knows what they're doing
Old Nov 13, 2013 | 05:08 PM
hav24wheel's Avatar
hav24wheel
The trim piece the radio is in? Ya, give it a tug.
Old Nov 13, 2013 | 05:13 PM
Money-Pit's Avatar
Money-Pit
Whoa.....inside the radio hole...2 bolts on top. Take them out before you crack your dash. I removed mine last weekend.
Old Nov 13, 2013 | 05:17 PM
hav24wheel's Avatar
hav24wheel
I've pulled mine out with the radio still in it.... So guess mine is missing screws than?
Old Nov 13, 2013 | 05:22 PM
Money-Pit's Avatar
Money-Pit
Maybe.....I pulled like a *****....thought it was gonna crack....noticed radio area was sticking. Looked inside and found the 2 screws.
Old Nov 13, 2013 | 05:26 PM
Metalhead47
Thank you, that's exactly the critical, need-to-know information I needed to know. Panel popped out like buttah after that. Now that's it's disconnected & sitting on the floor, will it mess anything up to start the truck without all the switches & such connected? I'm guessing not, but never know with computers....
Old Nov 13, 2013 | 05:28 PM
Money-Pit's Avatar
Money-Pit
I cranked my 6.0 up with no issues....dunno what you have
Old Nov 13, 2013 | 05:40 PM
kornfanjoe's Avatar
kornfanjoe
It will drive fine but you won't have headlights
Old Nov 13, 2013 | 05:47 PM
Money-Pit's Avatar
Money-Pit
If you have to drive it....pull the switches out of the dash bezel and hook them up.
Old Nov 13, 2013 | 06:37 PM
Metalhead47
Thanks for the info guys. No worries, that went back together quick & easy. Ran out of daylight so today was mostly a scouting expedition.
Next headache is to find a spot in the firewall to route some wiring thru (pass-thru wires on the factory harness won't work, gauge sender cable).
Old Nov 13, 2013 | 06:57 PM
Money-Pit's Avatar
Money-Pit
You're installing gauges? So am I. I 'll have some tips/pics for you this weekend. Do you have auto or manual tranny?
Old Nov 13, 2013 | 06:59 PM
Money-Pit's Avatar
Money-Pit
Duh....I'm in the excursion forum... Nevermind
Old Nov 13, 2013 | 07:26 PM
Metalhead47
Well "gauge" would be more specific, just fuel pressure right now & laying some groundwork for the others. Coolant temp goes in around Thanksgiving when I do the flush & filter, oil temp when I change the oil & add the bypass filter. The rest when I can get around to it. And to clean up the dangling wires from my backup camera.
Hmmm, manual Excursion... THAT would be kind of awesome!
Old Nov 14, 2013 | 02:32 PM
robert_l_ross's Avatar
robert_l_ross
There is a hole in the firewall above the brake...rubber oval cap on one side, foil insulated looking diamond cutout on the other...huge opening you can pass wires through.
Old Nov 14, 2013 | 05:09 PM
kornfanjoe's Avatar
kornfanjoe
the pass through wires will work. that gauge works on voltage reference, its given direct voltage and then the sender unit, acts as a resistance based on the pressure. more pressure = more resistance. the gauge then reads how much voltage was lost and translates that into a number.
i used the clutch hole above the brake pedal anyways its easy to get to. i also have a lot of wires back and forth
