Champion Radiators Part #
I had to replace the radiator in a 74 F250 with a 360. I had a hell of a time finding the correct radiator due to the fact that the mounting bracket had to be on the engine side of the radiator. I called Champion and they told me that they had just started to manufacture this radiator. The engine side number is CC444 and the grill side is cc443 just for your information.
Jim
Jim
Thanks. Got a pic of your setup for reference? We talk about the differences now and then, but I don't remember seeing any detailed shots.
I believe I have what you would call the grille side CC443 version. Where the full mounting flange is on the radiator, and it bolts directly on to the flat surface of the core support.
The one it sounds like you have is the one with a flat flange on the radiator, that bolts to an actual extension bracket on the core support. Correct?
Funny the opposite happened to me the last time I needed one. All the ones they looked up were the one you have, while I needed the other one.
Are you going to be buying a Champion once they're available? Or are you just going to keep the one you already have?
Paul
Paul
Now isn't that interesting! Looks almost as if they simply reversed the mounts on the radiator so it could be bolted right to the support.
Does your truck have A/C or not? And is that the Super Cool size? Looks like maybe not, but not sure.
In our cases our trucks are 4 model years apart so that could have been the main difference. But if no A/C on yours, maybe that's another reason for the change.
Thanks for the pic!
I'll take one of mine as soon as I get the chance so we'll have both styles here in one thread.
Paul
Thanks for the pic!
Paul
I have been doing some homework on radiators mine is a 66 and all together different but champion has had some killer reviews when it comes to customer service and support, one gentleman on here actually took his truck to champion and they modified his on the spot, that was after he had received a couple from them as he tried to make things fit. Bottom line is their c/s appears to be spot on. Good luck with yours
kr98664
23
01-05-2018 10:47 PM
jtindale
09-17-2013 11:58 PM
55forder
25
03-17-2005 11:46 AM
