Champion Radiators Part #
Old Sep 22, 2017 | 02:42 PM
otnot's Avatar
otnot
I had to replace the radiator in a 74 F250 with a 360. I had a hell of a time finding the correct radiator due to the fact that the mounting bracket had to be on the engine side of the radiator. I called Champion and they told me that they had just started to manufacture this radiator. The engine side number is CC444 and the grill side is cc443 just for your information.
Jim
Old Sep 22, 2017 | 03:44 PM
1TonBasecamp's Avatar
1TonBasecamp
Thanks. Got a pic of your setup for reference? We talk about the differences now and then, but I don't remember seeing any detailed shots.
I believe I have what you would call the grille side CC443 version. Where the full mounting flange is on the radiator, and it bolts directly on to the flat surface of the core support.
The one it sounds like you have is the one with a flat flange on the radiator, that bolts to an actual extension bracket on the core support. Correct?
Funny the opposite happened to me the last time I needed one. All the ones they looked up were the one you have, while I needed the other one.
Are you going to be buying a Champion once they're available? Or are you just going to keep the one you already have?
Paul
Old Sep 23, 2017 | 08:29 AM
otnot's Avatar
otnot
Here are the pictures of a 444 radiator. Notice the wide mounting bracket is towards the back of the radiator.
Old Sep 23, 2017 | 01:58 PM
1TonBasecamp
Now isn't that interesting! Looks almost as if they simply reversed the mounts on the radiator so it could be bolted right to the support.
Does your truck have A/C or not? And is that the Super Cool size? Looks like maybe not, but not sure.
In our cases our trucks are 4 model years apart so that could have been the main difference. But if no A/C on yours, maybe that's another reason for the change.
Thanks for the pic!
I'll take one of mine as soon as I get the chance so we'll have both styles here in one thread.
Paul
Old Sep 24, 2017 | 06:53 AM
66ordie's Avatar
66ordie
I have been doing some homework on radiators mine is a 66 and all together different but champion has had some killer reviews when it comes to customer service and support, one gentleman on here actually took his truck to champion and they modified his on the spot, that was after he had received a couple from them as he tried to make things fit. Bottom line is their c/s appears to be spot on. Good luck with yours
Old Oct 16, 2018 | 11:43 AM
hawkeyegold's Avatar
hawkeyegold
little older thread but did the champion rad work for the rear mount flange? i have the same setup.. thinking of ordering there CC444 Rad..
Old Oct 16, 2018 | 12:54 PM
otnot's Avatar
otnot
Yes it did. I had to drill new holes through the radiator flange but other than that it has worked just fine.
Old Oct 16, 2018 | 12:57 PM
hawkeyegold
ok great thanks! did you drill holes for the shroud as well? sounds simple enough
Old Oct 16, 2018 | 01:06 PM
otnot's Avatar
otnot
No I used the original holes in the mounting brackets so the shroud would fit.
Old Oct 16, 2018 | 01:08 PM
hawkeyegold
ok thanks! much appreciated..
Old Oct 16, 2018 | 05:36 PM
66ordie's Avatar
66ordie
Same here, I drilled new holes in the core support because I ordered a new one and modified it, the radiator is great and well worth the research I conducted and couldn’t be happier
kr98664
23
Jan 5, 2018 10:47 PM
jtindale
Sep 17, 2013 11:58 PM
dennisb56
Mar 20, 2011 05:36 PM
tude
Nov 1, 2005 05:01 AM
55forder
25
Mar 17, 2005 11:46 AM
