Pulley Ratio Question
1968/72 F100/350 360/390 single sheave outer crankshaft pulley is 6 25/32" O.D. and its ID engineering number: C8AE-6A312-B
1968/72 F100/350 360/390 double sheave outer crankshaft pulley is 6 21/32" large pulley; 6.00" small pulley and its ID engineering number: C8AE-6312-C
There's also a triple sheave outer pulley for P/S & A/C
Look on the Ford pulley for its ID engineering number, post what it is.
I found this string on an Ford Mustang site
Explain how a smaller crank pulley makes more HP? - Ford Mustang Forums : Corral.net Mustang Forum
I like to have my crank pulley at least as big as my water pump pulley it you plan to idle through town. At high way speed it won't matter much what your crank pulley size is. If you're going to drag race and spin 6000 rpms then get an electric pump and fans to minimize power loss. Otherwise, get a bigger crank pulley.
I think the string you found on the mustang site has a little correct but is mostly mixed up. Decreasing the crank pulley size will decrease the accessory speed. Also, the sizes don't make sense. A 40" diameter pulley is bigger than your tires. Even if they meant 40" circumference, that would still be a whopper big pulley.
Well I'm keeping my fingers crossed, I found an Bump owner with a spare three groove that he is selling me. I only hope its the correct size, the last one I bought online was for a 302
Originally Posted by pchelp;17343345[B
][/B]Well I'm keeping my fingers crossed, I found an Bump owner with a spare three groove that he is selling me.
I only hope its the correct size, the last one I bought online was for a 302.
(2) 7 5/32" inner pulley diameter / 7 13/16" outer pulley diameter / 3/8" belts on inner pulleys / 1/2" belt on outer pulley.
1968/71 F100/350 360/390 // 1968 Galaxie/LTD 390/428.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
Holehawgg
03-15-2014 09:44 PM
tractormanbill
01-10-2014 01:15 PM
JefflovesF250s
12-02-2004 05:25 PM
10charlie2
Performance & General Engine Building
12-19-2002 10:21 PM
