Power steering added to 352 in a '66 F250
on
Have accumulated most parts needed to add P/S to my F250 resto. Not sure what crank pulley I need to drive P.S pump. Alternator and cooling pump each have a double pulley, so it seems I will need the harmonic balance pulley (with a pulley groove in it) plus a double pulley on the crank. Or do I need to add a separate (3rd) pulley to the HB and single I already have? If adding a 3rd is the correct way to go what diameter pulley do I need for my addition (3rd)? I'm sure there's an expert out there, please speak up. Jeff
Before I put AC on mine (dont ask me to explain THAT...), this is how it ran. One belt goes from the crank to the fan to the alternator. The other one goes from the crank to the fan to the power steering.
I'd go get the pulley changed from dual to single on that alternator, or just run it on one. It doesn't really need two belts driving it.
abyars111
10-08-2015 12:05 PM
