Pulley Ratio Question
Old 07-19-2017, 08:47 PM
pchelp's Avatar
pchelp
pchelp is offline
I have replaced the crank pulley on my 390 because I added power steering and plan to add AC at a later time. My problem is the new pulley is quite a bit smaller, how will this affect the water pump and alternator?
Old 07-19-2017, 09:17 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
It will drive everything slower.... if this creates a problem, you'll need to install smaller pulleys on everything else.
Old 07-19-2017, 09:27 PM
pchelp's Avatar
pchelp
pchelp is offline
Ugh why don't the vendors put this information in their discerption!?
Old 07-20-2017, 06:50 AM
TeachNlive4ever's Avatar
TeachNlive4ever
TeachNlive4ever is offline
.....mo money.....
Old 07-20-2017, 07:03 AM
ultraranger's Avatar
ultraranger
ultraranger is offline
Old 07-20-2017, 09:03 AM
pchelp's Avatar
pchelp
pchelp is offline
Wait a minute now, hold the bus. So if i reduce the size of the crank pulley the alternator and water pump spin faster ?
Old 07-20-2017, 09:09 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Look on the Ford pulley for its ID engineering number, post what it is.
1968/72 F100/350 360/390 single sheave outer crankshaft pulley is 6 25/32" O.D. and its ID engineering number: C8AE-6A312-B
1968/72 F100/350 360/390 double sheave outer crankshaft pulley is 6 21/32" large pulley; 6.00" small pulley and its ID engineering number: C8AE-6312-C
There's also a triple sheave outer pulley for P/S & A/C
Old 07-20-2017, 09:19 AM
pchelp's Avatar
pchelp
pchelp is offline
I'll have to get the exact numbers tonight after I get home, but looking at the photo above you hit the measurements exactly
Old 07-20-2017, 10:50 AM
pchelp's Avatar
pchelp
pchelp is offline
Old 07-20-2017, 04:54 PM
'65Ford's Avatar
'65Ford
'65Ford is offline
I like to have my crank pulley at least as big as my water pump pulley it you plan to idle through town. At high way speed it won't matter much what your crank pulley size is. If you're going to drag race and spin 6000 rpms then get an electric pump and fans to minimize power loss. Otherwise, get a bigger crank pulley.
I think the string you found on the mustang site has a little correct but is mostly mixed up. Decreasing the crank pulley size will decrease the accessory speed. Also, the sizes don't make sense. A 40" diameter pulley is bigger than your tires. Even if they meant 40" circumference, that would still be a whopper big pulley.
Old 07-20-2017, 09:03 PM
pchelp's Avatar
pchelp
pchelp is offline
Here it is Number
Old 07-21-2017, 09:29 AM
NumberDummy
1968/72 F100/350 360/390 single sheave outer crankshaft pulley: 6 25/32" O.D. / Marked with ID engineering number: C8AE-6A312-B
C8AZ-6A312-E .. Outer Crankshaft Pulley-Uses 3/8" wide belt / Obsolete
1968/72 F100/350 360/390 / 1968 Galaxie/LTD 428 / 1968/69 Galaxie/LTD/Fairlane/Torino/Mustang/Cougar 390.
Old 07-21-2017, 09:36 AM
pchelp's Avatar
pchelp
pchelp is offline
Well I'm keeping my fingers crossed, I found an Bump owner with a spare three groove that he is selling me. I only hope its the correct size, the last one I bought online was for a 302
Old 07-21-2017, 10:17 AM
NumberDummy
Originally Posted by pchelp;17343345[B
][/B]Well I'm keeping my fingers crossed, I found an Bump owner with a spare three groove that he is selling me.
I only hope its the correct size, the last one I bought online was for a 302.
C8AZ-6A312-B .. Triple Sheave Outer Crankshaft Pulley (bolts to the harmonic balancer) / Marked: C8AE-6312-B / Obsolete
(2) 7 5/32" inner pulley diameter / 7 13/16" outer pulley diameter / 3/8" belts on inner pulleys / 1/2" belt on outer pulley.
1968/71 F100/350 360/390 // 1968 Galaxie/LTD 390/428.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
Holehawgg
03-15-2014 09:44 PM
rangerottis
02-26-2014 11:27 AM
tractormanbill
01-10-2014 01:15 PM
JefflovesF250s
12-02-2004 05:25 PM
10charlie2
12-19-2002 10:21 PM
Quick Reply: Pulley Ratio Question
