pcv hose
pcv hose
This truck is the gift that keeps on giving. So I found when I removed the carb that a previous owner has pieced together this pcv hose from the pcv valve to the carb base plate. Looks like they used a coupling and a piece of 5/8" heater hose to make up the difference. Not sure why it was done. Maybe it was the wrong size hose or possibly it had a leak. In any case I looked online and found a molded hose at several vendors. Not sure if what I am seeing online is correct because there were two listed and the one that was supposed to be for a 1967 f250 352 FE looked like it was u shaped which doesn't seem like it would line up with the carb base plate. There is a part number 78FB on the hose but I did a search and it didn't seem to be a Ford part number.
C5AZ-6A664-A .. PCV Hose-smog valve to carburetor spacer plate / 20 5/32" long / Obsolete
1965/66 F100/350 352 / 1967 F100/350 352 before change L/9.
C7TZ-6A664-A .. PCV Hose-smog valve to carburetor spacer plate / 5/8" I.D. valve end; 1/2" I.D. tube end / Obsolete
1967 F100/350 352 from change L/9.
377394-S .. Rubber Grommet-smog valve to valve cover / 1 7/16" O.D. x 23/32" I.D. / Obsolete ~ Available NOS
1965/66 F100/350 352; 1967 F100/350 352 before change L/9.
C7AZ-6A892-A .. Rubber Grommet-smog valve to valve cover / 2 5/64" O.D. x 45/64" I.D. / Obsolete ~ Available NOS
The nipple on a PCV is not 5/8". It's smaller. Looks like your hose connected up to the 5/8" nipple that should be in the other valve cover. Where there should be a hose connected to the air filter so the PCV system gets clean air.
I believe you are correct.
The hose is available repro- https://cgfordparts.com/ufolder/ford...r=C7TZ-6A664-B
I was gone a few days and didn't get back. Hope this helps.
sandcritter
06-01-2017 04:28 PM
jemini
09-03-2016 05:49 AM
