EX Drain Oil Pan Plug
Any found a plug that will screw in the back of the EZ Oil Pan Plug.
I just put one on and I'm not liking how the ball in the valve is so exposed to the road elements. I can't get the drain hose adapter locally and will have to order one but in the mean time I thought I would try a synthetic plug if I can find one.
As always, thanks in advance
Brice
Brice
Brice
Brice
Karl, yes exactly.
I add the ex drain for the sole purpose of not splashing the oil all over the garage floor when changing the oil and to get an oil sample down the road. it doesn't bother me to crawl under and pull a plug. I just want to keep as much of the road dirt and mud out of it as possible. I know over time dirt can scar the ball valve and seat witch will cause the valve to leak.
Cascade, thanks for the idea. I never thought about a rubber cap.
All thanks for the replies.
Brice
Brice
Also got a straight hose barb fitting, and a clip to hold valve closed just in case...
Small plug cap PC-001 | EZ Oil Drain Valve
