EX Drain Oil Pan Plug
Old May 24, 2017 | 02:18 PM
bkuuz1's Avatar
bkuuz1
Any found a plug that will screw in the back of the EZ Oil Pan Plug.
I just put one on and I'm not liking how the ball in the valve is so exposed to the road elements. I can't get the drain hose adapter locally and will have to order one but in the mean time I thought I would try a synthetic plug if I can find one.
As always, thanks in advance
Brice
Old May 24, 2017 | 05:35 PM
System's Avatar
System
Prolocutor
So, you bought a valve to eliminate the drain plug and now you want to put a drain plug in the valve? No need Brice...
Old May 24, 2017 | 10:08 PM
CascadeF250's Avatar
CascadeF250
Brice
Stop at your local hardware and buy a 3/8 size rubber cap For nearly nothing and that should handle your problem. I actually just did that. I'm sorry I cant remember what it cost but it was next to nothing.
Old May 25, 2017 | 06:16 AM
capt caper's Avatar
capt caper
I live on dirt roads with snow many months of the year.. no issues with mine.. so don't worry.
Old May 25, 2017 | 09:32 AM
bkuuz1's Avatar
bkuuz1
Karl, yes exactly.
I add the ex drain for the sole purpose of not splashing the oil all over the garage floor when changing the oil and to get an oil sample down the road. it doesn't bother me to crawl under and pull a plug. I just want to keep as much of the road dirt and mud out of it as possible. I know over time dirt can scar the ball valve and seat witch will cause the valve to leak.
Cascade, thanks for the idea. I never thought about a rubber cap.
All thanks for the replies.
Old May 25, 2017 | 11:51 AM
allcool's Avatar
allcool
Brice
I got one of these from EZ($1), it screws right into valve opening after oil change and caps it off nicely. Not so sure its needed, but **** me likes it..lol.
Also got a straight hose barb fitting, and a clip to hold valve closed just in case...
Small plug cap PC-001 | EZ Oil Drain Valve
Old May 25, 2017 | 12:56 PM
bkuuz1's Avatar
bkuuz1
Allcool,
Thanks!
Exactly what I'm looking for.
MG250
6.7L Power Stroke Diesel
37
Dec 29, 2020 09:54 PM
A/Ox4
30
Jul 14, 2019 10:26 AM
FSJ-EARL
16
May 12, 2015 10:10 PM
cam1394
Jan 2, 2006 09:28 PM
HD
Oil & Lubrication
16
Jun 11, 2003 05:49 AM
