1976 F150 390 low oil pressure
I have a 76 f150 with a 390.
And for some reason its losing oil pressure .. Now it's a LOW right at the end.
I noticed theres oil leak by the distributor.
Could i damage the engine if i drive it like that?
And what can i do to check it and fix it?
Is some i better take to mechanic shop?
Dont panic yet
I wouldn't panic yet, most of that oil residue you see in that pic is most likely coming from where the intake manifold meets the block and or the valve covers and or the timing cover and or a dozen other mating surfaces that leak on these motors as the years go by....
Dont freak out about installing a real oil pressure gauge its stupid easy, I know because I did it
, if your gonna give it a shot, just make a new post and we will get ya thru it.... its the only way your actually going to know where your true oil pressure is.... Other wise your going to drop $$$ at a shop and who knows what or how they are going to say or do.... Any auto parts store will carry the basic fluid in-line gauge for about $15-$25........
![Cool](images/smilies2/cool.gif)
![Big Grin](images/smilies/biggrin.gif)
Yep, another one on the real gauge. I run a cheap gauge from eBay and it shows 60psi cold idle on my tired old 351C and about 30psi hot.
The gauges come with a sensor that plugs into an oil gallery and senses the pressure, then sends that signal to the gauge. All you need to do it tap into an oil gallery, or simply remove the stock sensor and install the new one for the gauge.
- boingk
- boingk
78fordf150ranger
05-02-2010 01:17 AM
larryplummer
21
02-12-2005 06:35 AM
Sliderz
02-04-2004 10:27 PM
