low oil pressure
Old Feb 18, 2004 | 10:05 PM
mikey's 78's Avatar
mikey's 78
low oil pressure
im looking to purchace a 67 ford w/352 .but i was concerned about the oil pressure . idling it was about 15 to 18 psi . driving range was about 35 psi ..is this too low or about normal for this engine
thanks
mike
Old Feb 18, 2004 | 10:42 PM
Torque1st's Avatar
Torque1st
Posting Legend
Welcome to FTE!
Sounds low but you can check with the 352 engine forum for more info.
Old Feb 19, 2004 | 09:51 PM
mikey's 78's Avatar
mikey's 78
thank you for the info on the 352 forum .
as you can tell this is first time to use this site
Old Feb 19, 2004 | 10:19 PM
averagef250's Avatar
averagef250
That's awesome oil pressure for an FE! Do a search for low oil pressure and you'll find alot of great stories about FE's performing forever with hardly any oil pressure. My old 66 merc 390 hardly needed oil, let alone actual oil pressure to survive the 20K miles or so of me rodding the hell out of it.
Old Feb 19, 2004 | 10:38 PM
mikey's 78's Avatar
mikey's 78
thanks for the info
im just use to the 351m and 400 have much more pressure
i didnt want to make a bad purchase over oil pressure
Old Feb 19, 2004 | 11:47 PM
Fryzil's Avatar
Fryzil
When mine is warmed up it has 15 at idle and 45 on the pipe running 40w. Its not broke so im not fixing it.
Fry
Old Feb 20, 2004 | 02:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
My old 390 carried 30 psi hot at idle, 50 psi running hot, with 75 psi cold.
