Intake air temp sensor one circuit high and strange idle?
I have a code for iat sensor 1 circuit high. It's the only code I can pull. I replaced the sensor in the manifold and still no change. The truck revs up when started but kinda finds its idle rpm after a second and the idle fluctuates some when the truck is warmed up too. I have a snap on solus and all parameters seem to be good. Icp sensor is also new thinking it might be the cause. Other than that the truck runs perfect and doesn't miss a beat. Any ideas?
Sounds like a broken wire in the harness. Time to start looking at the harness.
Your going to want to dig out your DMM (Digital Multi Meter).
Do you have diagrams for the wiring?
It looks like to me that you have an 03 F350. If so and you don't have the
diagrams I can post them.
This file is from the 2004 truck and may not be the one you need
I'll get the file you need later today and upload it if you need it.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Look for pid IAT1 and IAT2. IAT1 is Intake Air Temp sensor #1. If you have a reading on the scanner,say 105°f, watch the reading and wiggle the wires at the plug and then work down the harness and inspect for chafe. If at anytime you see the temp change rapidly, like it drops to 40, then you found the problem area.
If you have no reading then you need to check for reference volts and a signal coming out from the sensor.
