P0161 Code on 97 F150 4.6L 4x4 - Ford Truck Enthusiasts Forums
Old 01-23-2007, 05:26 PM
jo97F1504x4
jo97F1504x4 is offline
jo97F1504x4 is starting off with a positive reputation.
I downloaded this code--O2 Heater Circuit Bank 2, Sensor 2. Can anyone tell me where sensor two is? I saw an orange sensor in the exhaust pipe that looks like it could be it, but don't know how to be sure or how to know if this is sensor two and not sensor one.
Thanks in advance.
Old 01-23-2007, 05:46 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) - Passenger side after the Cat. Look for damaged wiring, corrosion/water in the wiring connector. Good luck.
Old 09-28-2018, 11:15 AM
tcharron
tcharron is offline
tcharron is starting off with a positive reputation.
wait..isn't bank 1 the passenger side on a Ford? And bank 2 is driver side..
Old 09-28-2018, 11:49 PM
Bluegrass 7
Bluegrass 7 is online now
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
as Driver side in the middle of the rear cat.
The sensor is heated from a 12 volt supply through the harness as well as sends an Oxygen monitor signal on a separate lead to the computer for the health of the cats on that bank.
This checks the ratio of switching between the front and the rear as the way it does monitoring.
The Heater circuit function is in fault.
Good luck.
Mopar130
2009 - 2014 F150
01-04-2018 04:02 PM
krwg35
02-04-2016 11:38 AM
krwg35
02-02-2016 01:39 AM
Brandon50394
Aerostar
09-18-2012 02:43 PM
rml121
Aerostar
12-10-2003 10:02 PM
Quick Reply: P0161 Code on 97 F150 4.6L 4x4
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
