Heater Leaking Antifreeze
Old Oct 5, 2010 | 09:55 PM
Patrick2010's Avatar
Patrick2010
The hose beneath the heater on the passenger side is leaking on a 78 F100 I just bought. Whenever I drive it for a little while, I notice when I park it will leak antifreeze from the hose underneath the heater on the passenger side. It is not a lot but it makes a small puddle. I also noticed it smokes from the vents time to time when I drive it for awhile.
This is my first truck and a daily driver so Im trying to find a solution asap. Hopefully one that doesn't require buying a new heater.
Old Oct 5, 2010 | 10:01 PM
wyckedcombo17's Avatar
wyckedcombo17
can you physically see the hose leaking at the firewall? If so, alls you may have to do is tighten/get a new hose clamp.
If you can't see where its leaking from and you have a puddle on the passenger side floorboard, its more likely than not your heater core. I actually just replaced mine today, it was a 2 hour job (I don't have A/C though)
Old Oct 5, 2010 | 10:09 PM
solafide6's Avatar
solafide6
if it ends up being the heater core, you can easily bypass it for free with a couple of airplane clamps. depends on how badly you want a heater.
Old Oct 6, 2010 | 11:56 PM
fordracing19's Avatar
fordracing19
I did mine last week. Took 45min and I have factory a/c.
Old Oct 7, 2010 | 07:59 AM
Roller150's Avatar
Roller150
Fordracing19, you did yours really quick. Whats the trick because when it comes time I would like to be ready to tackle this job with out issues. I have factory A/C too. 79 f350
Old Oct 7, 2010 | 09:39 AM
fordracing19
No real trick. I just tilted the evap core up and pulled the heater core out. On the 97+ F150 i have those down to 1 1/2 hours. You have to pull the dash back on those.
Old Oct 7, 2010 | 10:47 AM
Roller150's Avatar
Roller150
Ok good, I was reading in my Haynes book about this and it makes it sound like there is a bunch to it.
Old Oct 7, 2010 | 03:23 PM
Behemoth's Avatar
Behemoth
Das core est kaput!
You can always tell when we're transitioning toward winter...there's a period where we see a rash of heater core threads pop up on the board. Once the temperature dips, and guys change that temperature vane to warmer, whatever corrosion the core has been going through during the summer becomes obvious quickly.
That was one of the things I made sure to do on my build, was to put a brand spankin new core in the heater box after the paint was complete. I call it "tactical laziness"...fix something when it's easy, even if it doesn't need fixing, as it's a pain in the butt when it's an actual problem (10 degrees outside, wet carpet, fogged up windows, etc. etc. etc.)
Old Oct 7, 2010 | 03:33 PM
jdscooby's Avatar
jdscooby
Originally Posted by Behemoth
Das core est kaput!
I kinda like it like that. Reminds me of a sauna
Old Oct 9, 2010 | 12:24 AM
Patrick2010
Thanks for the advice. The leak isn't on the floorboard it leaks onto the ground. Im going to work on it this weekend. Does anyone know where I could find a explosion type diagram of the heater?
Im planning on taking it apart to see whats going on and maybe replacing the heater core. Also anyone know how the hoses connect to the heater are they welded?
Old Oct 9, 2010 | 06:38 AM
jim collins's Avatar
jim collins
Inlet and outlet pipes sodered to the core just like a small radiator, hoses clamp to them.The clamps may be working loose and,or the hoses are starting to rot away. They are kinda hard to see and get to. Try a search for heater diagram.
Hardcase_Ford
Bronco II
Nov 11, 2008 10:07 AM
robmic20
Aerostar
16
Aug 15, 2007 07:54 AM
broncobuster7
Dec 6, 2006 12:05 PM
rowdie-stang
1997 - 2003 F150
Aug 2, 2005 09:16 AM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
Apr 21, 2003 08:09 AM
