antifreeze leak
Old Dec 3, 2006 | 11:20 PM
broncobuster7's Avatar
broncobuster7
antifreeze leak
What will cause antifreeze to leak inside the cab on passenger side? Heater core has been replaced.
Old Dec 4, 2006 | 04:19 AM
srercrcr's Avatar
srercrcr
Sounds like it needs to be done again.
Old Dec 4, 2006 | 08:35 AM
Coneynew's Avatar
Coneynew
Also, if you just replaced it, double check the 2 hoses you reconnected ti the heater core tubes. If they leak there, the cooland can run down the heater core tubes and into the cab.
Old Dec 4, 2006 | 08:37 AM
Sycostang67's Avatar
Sycostang67
Check the hose connections under the hood too. The coolant can run along the tube into the heater core case. It is possible you could have blown the new one too. I have to replace the core in my wifes 79 Capri every year. At least it only takes 20 minutes and the core is free under warranty.
Old Dec 5, 2006 | 11:36 PM
broncobuster7
Thumbs up
Thanks guys for the advice. I checked the hoses to the core and retightened them and I haven't seen a leak yet. Plus I think some of what I thought was leakage was the remaining that was left over inside the core casing. You all have been a big help.
Old Dec 5, 2006 | 11:48 PM
broncobuster7
years that will fit
How far into the '90's Ford pickups body parts are compatible to a 1986 Ford F150 Lariat XLT 4X4 long box
Old Dec 6, 2006 | 12:05 PM
Sycostang67
Up to 96 for the F-150 parts and up to 98 for the F-250/350 parts.
78150custom
Jan 23, 2012 09:40 PM
Frank_D
Nov 19, 2009 09:32 PM
dave87
Oct 12, 2009 10:29 AM
Ed the outdoorman
Oct 28, 2004 09:41 AM
dzjammer
Feb 2, 2001 03:14 AM
