Camshaft upgrades for F4TE Roller Motor?
Received 1,032 Likes
on
Actually if the motor has a crank sensor there's a good chance it is mass air and that opens up your cam choices. The 5.0HO cam is a good choice, but even better would be something like the Comp 35-320-8, it's essentially a high lift HO cam with more overlap and both of these things help to make more TQ. Note that the cam actually produces 0.512" lift with the stock 1.6 rockers and 1.7 rockers are not manditory despite what Jegs or Summit would seem to imply.
Conanski-
Thanks for the input. Yes, it is mass air. I do have 1.6 roller rockers on the engine now. Hate to spend more on 1.7s. I had seen the comp am you are referring to at Summit. Dang that seems expensive, but it seems to be one of VERY few options out there. I wrecked my 95, and am pulling the motor with all its goodies and putting it in a 96.
Thanks!
Thanks!
This is what has been on the motor over stock
351w Edelbrock Truck intake-
Z 303 heads
1.6 full roller rockers
lightweight h con rods
Twin 62mm BBK Throttle body
Bassani headers
Bassani 3" Y tube, Dual exhaust (Cat delete)
F-150 Lightning Powerdyne Supercharger
The only thing I have left that is stock is the camshaft and the block itself. I have larger injectors, but I will have to have the MAF redone and the ECM reprogrammed.
Z 303 heads
Bassani headers
TexasGuy001
20
05-21-2021 09:20 AM
retired ironworker
02-08-2015 10:38 AM
timbersteel
33
01-30-2013 04:50 AM
cjben
03-15-2009 12:20 PM
BigBlockF-250
07-24-2005 08:56 PM
