Sponsored by: Real Truck
06 F250 Pinion Bearing...HELP!
Old Jan 30, 2010 | 07:44 PM
novafreak66's Avatar
novafreak66
Question 06 F250 Pinion Bearing...HELP!
I need Help!
I'm trying to find out what the rear end is in this truck.
My parts guy tells me that it's a Sterling 10.5, Chilton DIY tells me that it's either a Sterling or a Dana 60. Haynes tells me that it's a Dana 80.
I'm confused .
My question is what is the Pinion Bearing Preload. I replaced the pinion seal about a month ago, and now it's got metal in the oil and you can feel a bearing grind in the pinion area.
Thanks!!
Old Jan 30, 2010 | 11:03 PM
rebelyell618's Avatar
rebelyell618
should be a sterling 10.5
cant help ya out on the bearing but there are alot of people on here that can.
Old Jan 31, 2010 | 04:54 AM
redford's Avatar
redford
FTE Leadership Emeritus
The single rear wheel trucks use a Sterling 10.5 differential. The DANA 60 is up front. DANA 80s are found on DRW trucks, F-450 and up I think (maybe F-350 also).
Old Jan 31, 2010 | 06:56 AM
senix's Avatar
senix
yup, I agree Sterling 10.5 on that truck. Sounds like a rebuild is in order if you have metal. That may mean pulling the diff out.
Old Jan 31, 2010 | 12:57 PM
cartmanea's Avatar
cartmanea
Do yourself a favor and take it to a shop that does a lot of differential work. If the pinion bearing is damaged you could have damaged the ring/pinion as well. Setting up preload is very important, I'm guessing you didn't get it tight enough the first time.
majestek12
Sep 16, 2015 02:06 PM
rlpatte
Mar 27, 2015 10:45 AM
cuellar23
Nov 28, 2013 10:45 AM
tastyklair
Aug 23, 2007 11:12 PM
