Lund visor
Old Jan 6, 2010 | 05:31 AM
Fordsflylow's Avatar
Fordsflylow
Lund visor
Has 8 bolt setup and bolts up to the cab. Making noises from being loose when at highway speeds. Very annoying! Problem is the holes have become rusted weakening the threaded surface on the cab which caused the bolts to loosen and not able to tighten. I tried using plastic anchors that expand and coated each hole with gasket maker before assembly. Worked great for a bit but problem is water will get between the cab and visor followed by freezing temps and pop loose.
Any suggestions on what product to use as a sealer and adhesive to fix this once and for all? Hate to have to take it off!
Old Jan 6, 2010 | 10:30 AM
clif1's Avatar
clif1
I used to build boats for a short time we used a urathan adhesive,sealent i think the name was bostick it was great stuff i think it would fix your problem. The only bad thing with it was if you had to take something apart that had been put together with it it usualy pulled the gellcoat off with it. Hope this helps
Old Jan 6, 2010 | 12:56 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Never installed one, but would nutserts work for the cab? They would space it up about 1/16" and allow the water to drain. A little sealer under them and some thread sealer for the bolts.
Old Jan 6, 2010 | 08:52 PM
e-tek's Avatar
e-tek
Two excellent recommendations!!
Old Jan 7, 2010 | 10:00 AM
Fordsflylow
Thanks for the suggestions guys, much appreciated!
Greg5OH
13
Nov 19, 2012 05:48 AM
Marcus Merritt
Nov 7, 2006 02:35 PM
cef2lion
Apr 10, 2006 03:03 PM
mcisme
Appearance & Dress-Up
Mar 17, 2004 07:27 PM
Rockwell
Paint & Bodywork
Jan 15, 2003 08:14 AM
