Dianostic Port
Old Dec 9, 2009 | 05:44 PM
Keith Niedermayer's Avatar
Keith Niedermayer
Dianostic Port
I am not getting an output to the port.
Someone told me that the fuse maybe blown.
Does anyone knkow where that fuse is located?
Old Dec 9, 2009 | 05:54 PM
xjcamaro89's Avatar
xjcamaro89
In the fuse panel..............................j/k.
But really it is , behind the kick panel on the passenger side. I dont know which one it is but there is a legend for the fuse block in the owners manual
Old Dec 9, 2009 | 06:06 PM
Keith Niedermayer
Tried all the fuses there and none are bad.
Any suggestions??
Old Dec 9, 2009 | 06:08 PM
Keith Niedermayer
Had a 2001 before this one and had same problem
tooke it to the dealer and they replaced the fuse and said it was under the hood
I'mmm confused
Old Dec 9, 2009 | 06:10 PM
xjcamaro89's Avatar
xjcamaro89
Well now that you say that there is a big box under the hood, and there is a bunch of fuses in there as well, i thought it would have been behind that kick panel, but you might as well check the ones under the hood as well.
Old Dec 9, 2009 | 06:16 PM
Djack04F150XL's Avatar
Djack04F150XL
Mine had the same problem and it was the lighter fuse that feed the OBD port. I don't remember which fuse number though.
Old Dec 9, 2009 | 06:20 PM
xjcamaro89's Avatar
xjcamaro89
I thought there was something that the ODB port shared power with but i couldnt remember, if the fuse in the box for it is ok, is there a inline one somewhere as well?
Old Dec 9, 2009 | 06:57 PM
n5926g's Avatar
n5926g
Not meaning to hijack a thread here,but my 07 shows"error" when my reader is plugged into the OBDII port...arent these OBDII vehicles? ALL my accessories work fine,and the truck is pristeen....what gives?
Old Dec 9, 2009 | 08:24 PM
mattd17's Avatar
mattd17
my 06 booklet says it is fuse 41, 20amp. it shares power with the lighter plug.
fuse 41 is on the left side column, about 2/3 of the way down, it is mounted in a verticle position, and is the lowest mini fuse.
hope this helps you.
Dmoe512
6.7L Power Stroke Diesel
Jun 29, 2014 10:23 AM
Icicle
May 30, 2014 02:37 PM
Danny Duggins
Nov 4, 2012 07:27 AM
wreedZ71
2004 - 2008 F150
Nov 23, 2008 06:37 PM
captain_trucks
6.4L Power Stroke Diesel
Feb 11, 2008 03:46 PM
