I can't figure out what reference in the manual is for the cigarette lighter outlets. It must be called something else now and after reading through all of them I can't put my finger on it. I do have power to the 110 outlet.
The fuses you are looking for are under the hood. Fuses 82, 83, 87, 92, 93. (I only know because I blew a fuse and spent 2 hours trying to find it.) Those are the aux fuses for the cigarette lighters and outlets. I don't know what would cause them all to go or if there is something else wrong.
For inside the cab fuse box you have in slot 49 the relay for "delayed accessory" that also might be worth checking out.
they are called power ports.
I use the online manuals to be able to search
Most likely the J-case fuse under the hood near the master cylinder. Good luck finding replacement fuses locally. I have yet to find an auto parts store that carries them. I bought some on Amazon a few months back. They are expensive little rascals.
