Sponsored by: Auxito
Cruise Control Diagnostic Question
Old Oct 25, 2009 | 10:50 PM
redwood's Avatar
redwood
Question Cruise Control Diagnostic Question
My cruise doesn't work. When the button is pressed, there is no indicator light. The cruise won't engage at all. I printed out the troubleshooting sheets from alldata and did the whole test routine, and it turns out that the cruise control servo is bad. I have tried to get it to go into diagnostic mode to see if it would throw a flash code, and I can see the cruise indicator flash on to indicate programming mode, but it won't respond the rest of the key in sequence. I know the buttons are sending a signal because of the tests I ran previously. My question is this: Will a bad servo prevent the system from going all the way into diagnostic mode?
I don't want to spend the money on the servo only to find it was some other problem that was pointing at or being masked by the servo.
Old Oct 27, 2009 | 07:44 AM
l-m tech's Avatar
l-m tech
have the deactivation switch recalls been done on the vehicle.see if the fuse in the recall harness is blown.
Old Oct 27, 2009 | 07:54 AM
redwood's Avatar
redwood
The recall has not been performed.
Old Oct 27, 2009 | 07:21 PM
projectSHO89's Avatar
projectSHO89
Then get it done before proceeding. The recall work may fix the cruise problem, depending on the nature of the fault.
As an added bonus, your truck won't go up in smoke.
Old Oct 28, 2009 | 12:07 PM
hueyhound's Avatar
hueyhound
I had the same problem with my cruise control. I changed the brake pressure switch because it looked like it was leaking ($12.99), then I found out this was a recall issue so it was good because the fuse had blown. I replaced the fuse and the whole system worked perfectly, but the only thing is that the cruise light on the dash does not come on. Hope you figure it out.
HH
Old Oct 28, 2009 | 02:51 PM
redwood's Avatar
redwood
I'm thinkin' I'm gonna pick up a used cruise servo and see what happens...
XSleeper
Electrical Systems/Wiring
Mar 14, 2020 09:10 PM
quincyj34
Mar 9, 2016 04:13 PM
Tugly
38
Nov 25, 2014 07:02 AM
GuitarJesus
Jun 26, 2012 08:54 AM
