cruise control servo
Old Jun 25, 2012 | 09:26 PM
GuitarJesus's Avatar
GuitarJesus
Does anyone know if the gears inside the cruise control servo should be able to turn by hand? Trying to deduce why my cruise won't work.
Old Jun 26, 2012 | 08:54 AM
Intimnasc's Avatar
Intimnasc
I am not sure but I believe it is not even supposed to be opened. I would start by checking the pressure switch on the master cylinder, then the cluth switch if you have a standard, then the brake switch. I would also look into the clock spring in the steering column. Lastly if all else checks out you can buy a cruise control servo from the local JY and try it. I got the steering wheel with the cruise buttons and the servo for 24 dollars when I added cruise to my truck. Below is a link to adding cruise to a truck that does not have it but there is also some wiring diagrams in there that may help you.
https://www.ford-trucks.com/forums/1...e-control.html
FL7.3Diesel
Jun 4, 2018 11:10 AM
fordguy622
Aug 2, 2009 10:31 PM
Mark76f250
Sep 14, 2004 03:33 PM
