Cruise control servo
Old Mar 9, 2016 | 01:55 PM
quincyj34's Avatar
quincyj34
On my 92 I have the cruise control servo with vacuum hoses. I see on some trucks they have a different style that doesn't have vacuum hose. Is that an updated servo? Would I be able to use that style?
Old Mar 9, 2016 | 02:07 PM
POLARISrider500's Avatar
POLARISrider500
yes 92 to 93 they switched to electric and if you had the electric, you had a recall
Old Mar 9, 2016 | 02:15 PM
POLARISrider500
if it works, leave it, less worries of electronics and no risk of a fire, the reason there was a recall because fluid would leak from the master or the abs dead, (not sure which)and get on the connections and start your fire there. the recall added a make shift fuse from ford.
Old Mar 9, 2016 | 04:00 PM
quincyj34's Avatar
quincyj34
The one I have looks like this:
Old Mar 9, 2016 | 04:13 PM
rla2005's Avatar
rla2005
You would need the complete wiring harness, servo/amplifier assembly, BPS switch to make the swap work. Not impossible with a donor.
BPS= Brake Pressure Switch
busch6062
May 1, 2020 06:01 PM
dyoungen
Feb 20, 2011 03:44 PM
LARIAT 85
Sep 5, 2007 06:04 PM
EMoeFord
Jun 2, 2007 08:28 PM
douggant
Jan 9, 2004 07:36 PM
