PCM troubles
Old Dec 4, 2008 | 06:19 AM
KevinC.'s Avatar
KevinC.
PCM troubles
When trying to read trouble codes the computer cannot connect with the module, I'm guessing the PCM is bad. Does anyone know where I can pick a new one up other than from ford?
Old Dec 4, 2008 | 07:16 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
First off, what kind of scanner are you using to read codes? A lot of generic or over the counter scanners will not read diagnostic trouble codes in these trucks.
Old Dec 4, 2008 | 07:33 AM
plowhand's Avatar
plowhand
Playing in the Dirt
First let me say welcome to FTE. Cleatus is correct, the scanner has to be able to read Ford "Enhanced" codes and most scanners cannot.
What kind of problems are you having with your truck? The more info that you can provide on your truck (yr, auto or stick, 2wd or 4wd, what upgrades you have done, etc) and the more info that you can provide on the problem, the better we will be able to help you. So post up your problem and we will see what we can do.
Old Dec 4, 2008 | 09:52 AM
KevinC.'s Avatar
KevinC.
It is a 95 2WD F-250 with a 7.3 and a manual. It's bone stock now but have a lot in the works. It is idling very rough and lacking power. I tried swapping the PCM with one for an auto trans, it fixed all the motor problems but wouldnt work with my tranny.
As for the computer I was using, it is the one ford techs use that works off a lap-top.
Old Dec 4, 2008 | 11:33 AM
plowhand's Avatar
plowhand
Playing in the Dirt
If you are sure the computer is working O.K. (try it on another truck to make sure) and the PCM that you swapped into your truck fixed the problems, then yes it sounds like you PCM went south on you.
You might try: Car-Part.com--Used Auto Parts Market and look for a 97 PCM (updated programming) for a manual trans truck. I have found several close by and they were all good ones. Most salvage places will give you a return grace period on them, so if it does not work you can take it back (make sure you ask about this before you buy a used one).
There are several places that sell reman units. I don't have acess to my list now but I sure someone will post up with palces to get them.
Old Dec 4, 2008 | 02:46 PM
KevinC.'s Avatar
KevinC.
The computer checked out, so I am also thinking it is the PCM, thank you guys very much!!
Old Dec 4, 2008 | 04:27 PM
Action4478's Avatar
Action4478
If you have a manual ,,the auto should also work ...
What thigs didn't work...?
Old Dec 4, 2008 | 04:50 PM
KevinC.'s Avatar
KevinC.
It was weird, a lot of play in the transmission, almost like the way a bad u-joint feels. When I plugged the manual one back in that went away.
Old Dec 4, 2008 | 06:10 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Old Dec 4, 2008 | 07:44 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Found this one on Car-Parts: 1997 Engine Computer Ford Truck F350 not Super Duty; US Price $100; Stock# MRS71436; http://www.greenleafauto.com/locations.aspx; USA-FL(Tampa); 1-800-282-4283. I just picked this PCM: "Elec Cont Unit (ECU), (R side eng comp), 8-445 (7.3L, diesel), engine control, MT, std emis (Fed), ID F7TF-12A650-SB "
There were others in the Southeast, just do a search for 1997; Ford F250 not Super Duty (1999 and down); Engine Computer, then pick any of the four "MT, std emis (Fed), ID" numbers. Good Luck.
Old Dec 4, 2008 | 07:48 PM
KevinC.'s Avatar
KevinC.
Plowhand you are a life saver! I am actually going to Tampa tomorrow, I'll pick it up and let you know how it does for me. Thanks
Old Dec 4, 2008 | 07:53 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Like they say, "I'd rather be lucky than good".
But I think they also say "Even a blind squirrel finds a nut every now and then".
Old Dec 5, 2008 | 07:01 AM
KevinC.'s Avatar
KevinC.
I'm new on here, how do you get your vehicle info to show on a post? Or does mine and I just can't se it?
Old Dec 5, 2008 | 07:17 AM
plowhand's Avatar
plowhand
Playing in the Dirt
I think you have to have 25 post before it let's you add a signature. You can go to the "Testing" forum (bottom of all the forums) and do a bunch of test post to get you count up and then you can add a signature.
truckfella
Nov 12, 2014 04:02 PM
Automator
Aug 15, 2014 02:45 PM
mfp4073
1983 - 2012 Ranger & B-Series
Jun 17, 2014 02:38 PM
acf6
Dec 22, 2011 03:38 PM
