Help IDing a Motorcraft Carb
Old Jul 17, 2008 | 03:39 PM
DirtStripHero's Avatar
DirtStripHero
I have a 1974 460 in my F250 and I am trying to figure out what carb I have on it. I can't find any numbers anywhere. All I can see is the word Motorcraft stamped in the front. Does anyone know what carbs they used in this year?
Old Jul 18, 2008 | 12:55 AM
LxMan1's Avatar
LxMan1
Can you post a picture of it? Perhaps it is a 4300 series.
If the rear barrels are much larger than the front, then it is a 4350 series.
Old Jul 18, 2008 | 01:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The only ID numbers on Motorcraft carbs are on a triangular shaped tag that bolts to the airhorn.
9 times out of 10, the ID tag is missing by now.
As original: 1974 F250/350 460: Motorcraft 4300 4V carb / ID tag code: D4TE-9510-CA.
Carburetor tune-up kit: D3AZ9A586A (Motorcraft CT226B)
MSRP: $27.38 / FTEpartsguy.com price: $16.43
Old Jul 18, 2008 | 06:17 AM
DirtStripHero
The rear barrels are not much bigger, if any. Let me see if I can't get a picture on here tonight. But from what I had read here on the forum, I have a feeling its a 4300 series.
Old Jul 18, 2008 | 08:03 PM
LxMan1's Avatar
LxMan1
Sounds like it. Pretty good carbs.
Old Jul 18, 2008 | 10:05 PM
DirtStripHero
ok so it was dark when I got home so I couldn't get a good picture of it. But how well will these carbs flow? I plan on upgrading the cam soon and I think if I do that, I should probably look at upgrading the carb as well.
Old Jul 19, 2008 | 01:57 AM
LxMan1's Avatar
LxMan1
It should have a venturi size stamped in it somewhere. Look in the READFIRST thread at the top of this forum for more details.
Old Jul 19, 2008 | 11:34 AM
DirtStripHero
I looked at the READFIRST thread. The only problem is that my carb doesn't have any of those numbers stamped on it. It has a 1.25 stamped in the circle.
Old Jul 19, 2008 | 11:54 AM
DirtStripHero
I have no idea if this a stock carb or not. We found it in my buddy's barn along with a huge Q-jet and and three holley 2bbls that came off of a powerwagon. It is a squarebore design though
Old Jul 20, 2008 | 05:31 PM
LxMan1's Avatar
LxMan1
1.25 is probably the correct number. Maybe contact Carburetor, Carburetors, Carbs, Carb Parts. Pony Carburetors - Your Ford Carburetor Restoration and Part Sales Specialist for more info.
croosteringa
Sep 19, 2010 11:14 PM
fdude64
Sep 15, 2009 05:46 PM
dean307
Nov 24, 2006 11:36 PM
