Offroad & 4x4
broken gear box? chevy z71.
Old Apr 10, 2008 | 10:24 PM
stevoFX4's Avatar
stevoFX4
hi, i am new and about to get my 04 f150 fx4, and i have been mdding and off roading with my friends in z71 tahoes... a few of them have apparently gotten water in their gear box? and busted them. are there problems like that in mud with fords? thanks for the advice.
STEVO
Old Apr 11, 2008 | 08:53 PM
STGFordCrazy04's Avatar
STGFordCrazy04
gear box? You mean transmission?
if so...
Its always a good idea to change ALL fluids after coming in contact with deep water. Thats with Fords Chebbys Dodges Toyotas anything. If you friend regularly got water in his transmission and didnt change the fluid hes an idiot and he deserves the rebuild cost.
Old Apr 11, 2008 | 09:14 PM
bad96's Avatar
bad96
x2 stg,
oil is to reduce friction and heat in movin parts----i.e. trans,t-case,axles, etc.
water will displace oil and create problems vey quickly
Old Apr 11, 2008 | 09:19 PM
79-400-POWER's Avatar
79-400-POWER
no no no, if your gonna be in mud and watter alot, drain all the oil out of the transmissions transfercase and even the axles, and just run water. that way you dont have to worry about getting water in the oil.
Old Apr 11, 2008 | 09:20 PM
STGFordCrazy04
Brilliant! Why didnt I think about that? You could always top it off with water wetter or similar to aid in cooling.
Old Apr 11, 2008 | 09:48 PM
bad96's Avatar
bad96
so if i run Aquafina is that considered a full synthetic?
Old Apr 11, 2008 | 09:52 PM
STGFordCrazy04
yeah dont use regular water out the hose. The sediment will settle in the bottom and damage the bearings. Use purified water like aquafina. The 20oz bottles are perfect for pouring into tight spaces like trannys and tcases.
Old Apr 11, 2008 | 10:09 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
this could get interesting.
Old Apr 11, 2008 | 10:18 PM
Ford150/428/dud's Avatar
Ford150/428/dud
A water softner also improves water viscosity for better wear protection.
Old Apr 11, 2008 | 10:57 PM
73f100shortbed's Avatar
73f100shortbed
Brita makes some decent water filters if you are worried about proper filtration.
Old Apr 12, 2008 | 09:00 PM
Ryan50hrl's Avatar
Ryan50hrl
everyone knows gatorade works better....
Old Apr 12, 2008 | 09:22 PM
dragogt's Avatar
dragogt
I just had to throw this out there.
The Waterboy (1998) - Memorable quotes
Coach Klein: Gatorade not only quenches your thirst better, it tastes better too.
Bobby Boucher: No, you people are drinking the wrong water.
Coach Klein: Gatorade.
Bobby Boucher: H2O.
Bobby Boucher: H2O.
Coach Klein: [singing] Water sucks. It really, really sucks. Water sucks.
z71burb
Oct 5, 2007 05:22 PM
fordguy76
General Automotive Discussion
Jan 27, 2005 08:20 AM
moose94
63
Dec 26, 2004 04:08 PM
GMtoFord
Ford vs The Competition
Nov 16, 2004 06:30 PM
Dustin_86
26
Feb 7, 2004 11:26 PM
