Transmission oil analysis - from Jim McCarty
Old Apr 5, 2008 | 11:49 PM
bismic's Avatar
bismic
Attached below is an analysis of used transmission oil that another member (Jim McCarty) sent me. I promised a long time ago to post these results and am just now getting to it. I will PM him and hope he can post his comments below.
You may have to click on it to get it to enlarge.
Old Apr 6, 2008 | 11:39 AM
Jim McCarty's Avatar
Jim McCarty
I obtained this sample at the 30,000 mile service. I plan to run this oil to 45,000 but send in a sample at 30,000. The oil is Ford Mercon V - exactly what the manual calls for.
I haul some very heavy loads and I am totally impressed with the 5R100.
Contrary to some posts, under a light throttle, tow haul mode, 30,000 lbs GCW, it will use all six gears and it sounds really great when it does that.
Old Apr 6, 2008 | 02:00 PM
bismic's Avatar
bismic
Jim - 5R100 auto transmission? You do not have the Torqshift?
Old Apr 6, 2008 | 02:44 PM
Maxium4x4's Avatar
Maxium4x4
The 5R100 is the TorqShift...
Old Apr 6, 2008 | 03:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The TorqShift is the 5R110. There is no such thing as 5R100.
The analysis at the top says that the fluid they tested is MERCON SP.
Old Apr 6, 2008 | 04:51 PM
Kep4's Avatar
Kep4
Jäger
Thanks Mark! You guys had me going for a moment there. The 5R110 TorqShift uses Mercon SP exclusively.
Thanks for posting the report bismic and thanks to Jim for sharing his report. The T-shift is an amazing transmission behind an engine that just needs some massaging in a truck that is truly first class.
Old Apr 6, 2008 | 05:51 PM
bismic's Avatar
bismic
Mark - thanks for taking your time to post on our Forum - even on the topics that must seem basic to you! You are a tremendous resource.
Old Apr 6, 2008 | 06:23 PM
Maxium4x4's Avatar
Maxium4x4
Ooops my bad...... 5R110 I didn't notice it until Mark came along.
Old Apr 6, 2008 | 06:39 PM
j_lauer's Avatar
j_lauer
Sample?
How did you get the sample, I thought you had to drop the pan to change the filter and oil?
Maybe I missed something in the manual.
Thanks Jim for the great report.
Jeremy
Old Apr 6, 2008 | 07:52 PM
Bear Hunter's Avatar
Bear Hunter
06 Auto Tranny.... you have the wrong fluid
Edit: Nevermind...I see bismic posted results for Jim who apparently mis-spoke about the fluid type.
Old Apr 6, 2008 | 09:13 PM
Jim McCarty
My bad. I'm at Texas Motor Speedway and must confess to having at least a beer or two during my week-long tailgate party. Now that the races are over, I apologize for my typing and thinking. The finger was faster than the brain. It is a 5R110, regular ole transmission for the 2006 model 6.0 engine and it uses Mrecon SP and is changed at the Ford dealership. The did not drop the pan this time, but pumped out the old and pumped in the new at the same time. I snagged some of the old as it was coming out.
Hey, just because I can't think and type at the same time (OK, a beer may have been involved), do not let this detract from the main bit if information. That is that this transmission, using factor fluid, is one heck of a fine transmission.
Old Apr 6, 2008 | 09:33 PM
Kep4's Avatar
Kep4
Jäger
Jim, have you changed the external filter yet? The FT-145 'paper roll' under the right front in the aluminum canister.
Old Apr 7, 2008 | 07:50 AM
Jim McCarty
Yes, I always change the outside filter and changed inside filter once. It was clean but what the heck, the pans's off so you might as well replace it.
Old Apr 7, 2008 | 09:36 AM
sbrou14's Avatar
sbrou14
Good info indeed, I love the 5r110 myself.
Jim McCarty
Jul 27, 2015 09:53 AM
bismic
Jul 7, 2015 08:45 PM
Jim McCarty
Texas Chapter
Apr 4, 2007 06:11 PM
Jim McCarty
Jan 20, 2007 11:43 AM
Jim McCarty
Jun 29, 2006 12:17 AM
