Can't start truck!
Old Aug 3, 2001 | 10:24 PM
butaford's Avatar
butaford
Can't start truck!
I finally put my 79 F-150 together. The only way I can start it is by jumping from the hot side of the solenoid to the smaller terminal next to it with a screwdriver. I put a new ignition switch in because I had one laying around but that didn't help. The only other thing I have not tried was the neutral safety switch, but I don't know how to check it. Any ideas?
Old Aug 3, 2001 | 10:38 PM
desperado_18_2000's Avatar
desperado_18_2000
Can't start truck!
unplug the saftey switch from the trans and put a peice of wire into the two terminals. if the truck starts, then its the switch if not...you've probably got some wiring in front of you.
Old Aug 3, 2001 | 11:31 PM
Boss_358's Avatar
Boss_358
Can't start truck!
What about the fusable link that goes to the soleniod? Would this cause this problem?
People who say it can't be done should not interrupt the person doing it.
Old Aug 4, 2001 | 09:30 AM
butaford's Avatar
butaford
Can't start truck!
Thanks I'll look in to those suggestions today. Just incase anyone is wondering the starter, solenoid, battery, and ignition switch are all brand new.
Old Aug 5, 2001 | 01:45 PM
BeerMaker250's Avatar
BeerMaker250
Can't start truck!
Had the same problem with my 80 F-250.Changed starter,voltage regulator, solenoid(three times),Fusable link and could only get it to turn over by jumping the solenoid.
Seems I had forgotten to hook up the ground wire that goes from the firewall to the manifold,fixed that and my truck started right up.
Hope this helps,took me four days and several $$ to fix such a small problem.
Ken
Old Aug 5, 2001 | 05:38 PM
Franklin2's Avatar
Franklin2
Can't start truck!
mattb77
Oct 21, 2016 09:34 PM
Christopher Layton
Sep 22, 2015 07:45 AM
msfprobass
1978 - 1996 Big Bronco
Jul 19, 2014 10:45 AM
MUSKRATT2
Sep 15, 2009 07:05 AM
Dualiedo
Sep 25, 2002 09:21 PM
