EGR Valve???
Old Aug 4, 2001 | 06:05 PM
1ole4d's Avatar
1ole4d
EGR Valve???
Hi all...Got a question for ya's. I have a '78 351M completely stock. The last owner disconnected the vacuum line to the EGR valve and to the top to theair cleaner and all. With it like this the truck idles fine at about 600-700rpm like it should. When I connect the EGR valve to a vacuum source the truck wants to die and tries to idle around 200 rpm. Sounds like a V8 running on 1 cylinder. Any clues as to why hooking the EGR valve back up does this?
Old Aug 4, 2001 | 06:19 PM
Bill_Beyer's Avatar
Bill_Beyer
EGR Valve???
The EGR valve is bad and is causing a giant vacuum leak when it's hooked up.
Old Aug 5, 2001 | 05:38 PM
Franklin2's Avatar
Franklin2
EGR Valve???
I hope you are hooking the egr up properly. It does not go to a manifold vacuum source. It usually goes to a ported vacuum source from the carb, so there is no vacuum to the valve at idle. Also, along the way, the vacuum line usually passes through a thermostatic vacuum switch mounted in a coolant passage somewhere, that does not let the egr work at all till the engine is at least approx 100F.
Old Aug 6, 2001 | 01:51 PM
Bill_Beyer's Avatar
Bill_Beyer
EGR Valve???
