Sponsored by: Kumho
Steering column issues
Old Sep 14, 2009 | 06:27 PM
MUSKRATT2's Avatar
MUSKRATT2
I'm having an issue with my tilt steering column on my 85 F350. If I use the key I can't start the truck.I've eliminated the Ignition switch because I've tried to adjust both ways & that still didn't fix it. I can take the switch off & start it with a screw driver by activating the switch itself. What I have observed is that when you put the switch back on the column you can turn the switch till it starts buzzing but you can't get it to the start position. I looked down at the rod & it moves down till it gets to the start position & then it starts pushing up in the air. I haven't pulled the wheel off yet. My question is what could be wrong?
Old Sep 15, 2009 | 04:17 AM
Lazy K's Avatar
Lazy K
If it`s the same as my `87 then you have a broken actuator in the column. You will need to pull the wheel and the shroud to get to it.
Old Sep 15, 2009 | 07:05 AM
MUSKRATT2's Avatar
MUSKRATT2
Thanks' Lazy K!
Jdolson22
Aug 22, 2017 12:07 PM
Lord Vokk
Nov 16, 2016 10:51 AM
rusty_tank
Aug 19, 2016 05:08 PM
Bootlegger's Deluxe
31
Dec 14, 2015 10:34 PM
Action410
Jan 18, 2013 07:40 PM
