I was wondering what my transmission is the 04 deisel i traded was a torque shift. I dont know much about this stuff. And was wondering how tough the tranny i have is.
There's something wrong outside of the trans, or at least two of them were built wrong.
If the coolers are not replaced when the the trans is replaced it will often cause a repeat failure. It's impossible to get every bit of junk out of a used cooler. Sooner or later some of this junk can work loose and end up in the new trans and cause problems. Or there could be enough junk in the cooler to restrict flow and the trans overheats.
