Sponsored by: Auxito
98 F-150 plugs
Old Jan 29, 2008 | 11:27 AM
typhus's Avatar
typhus
98 F-150 plugs
Ive read about the horror stories on this forum about changing the plugs out on the 5.4s, but havent heard anything on the 4.6 engines.
I like to do most of the maintenance myself, but is this a job I really want to take on?
I have a 1998, and a friend that owns a 97 just did his, and said he would never do it again.
Im a little more mechanically inclined than he is though, but now Im a little more hesitant in attempting this.
Any advice, or opinions?
<!-- / message -->
Old Jan 29, 2008 | 12:24 PM
Boss50's Avatar
Boss50
It's not really that bad with a little patience. Just make sure you have a good plug socket and extension. (make sure they lock together tight).
Old Jan 29, 2008 | 12:31 PM
galaxie641's Avatar
galaxie641
Well the 4.6L isn't quite as tall so you'd have a little more room to work with. I've only done a 4.6L in a Grand Marquis and it was incredibly easy, but the trucks have the engines shoved half way under the firewall where as the cars don't. I won't do my 5.4L it just isn't worth my time to aggravate me that much, I tried once and have it done from then on.
Old Jan 29, 2008 | 12:50 PM
MisterCMK's Avatar
MisterCMK
Piece of cake. Make sure that you have a good set of extensions and swivels and go to town. It will seem difficult the first time, but after that it is fairly easy.
Old Jan 29, 2008 | 01:19 PM
typhus's Avatar
typhus
Thanks for the confidence boost, I have a nice goose neck snap-on ratchet that should be helpfull in getting under that friggin firwall. I love that ratchet.
Old Jan 29, 2008 | 01:48 PM
DanK5's Avatar
DanK5
I used a rubber filled socket to get them out and a length of fuel line to start the new ones and then a regular socket to run them in. Try blowing the holes out with air before you begin. Use anti sieze on the threads and dielectric grease on the boots.
I loosend but didn't remove the tall verticle PS reservoir bracket and removed the reservoir to gain a lil more room. I also unclipped the injector around where I was working so I didn't thrash it by accident. The back passenger side is the most difficult. Start with that one so each one will get easier. Oh. USE MOTORCRAFT PLUGS and MOTORCRAFT wires.
96DRW
Jun 15, 2012 04:30 PM
FordOwnerJoey
Oct 31, 2011 03:50 PM
rckslash2010
Mar 8, 2010 04:00 PM
Casino
Jan 16, 2007 12:53 PM
6String
1983 - 2012 Ranger & B-Series
Apr 7, 2005 06:35 AM
