Modular V10 (6.8l)
I saw it before in here
Old Oct 8, 2007 | 06:47 PM
01V10's Avatar
01V10
Hey guys,
I saw a thread like this before and I apologize for duplicating but I can not find it anymore. I ran some all fuel system cleaner through my truck (2001) and cleaned the K&N along with shooting some MAF cleaner on the MAF. Here is where i saw this before. My truck now sounds like it has a big cam in it when idling (honestly sounds pretty cool with all the exhaust work I have done) and the SES light is on. I took it down to Auto Zone and had them read the code it came up as the MAF or vacuum hose leak, I think i remeber something about left bank lean as well. I will have them pull the code again and I will post it tomorrow. They cleared the code for me and after a day it has come back on. Now it doesn't have big the lopey sound to it at idle but it does idle high now and the revs don't fall as quick as before when in Drive. Like I said I know I saw a simlar post to this but I can't find it anymore. You guys have been helpful in the past and looking for help again. Thanks in advance.
Old Oct 9, 2007 | 07:53 AM
SLE's Avatar
SLE
Sounds like the ever so commen little 90* elbow that cracks out. easy and cheap to change. good luck.
Old Oct 9, 2007 | 08:38 AM
jonrjen's Avatar
jonrjen
Could it be you over oiled the KN and the MAF is getting oil on it as the air is sucked through the filter, past the MAF on its way to the intake? Just a thought of a common mistake with the reusable filters.
Old Oct 9, 2007 | 09:33 AM
dkf's Avatar
dkf
I ALWAYS take my MAF sensor completely off the intake for cleaning. There are several wires that need many direct shots with the cleaner to clean them properly. I use CRC MAF cleaner.
The MAF is probably not your problem though.
As SLE said I would check the elbow.
Old Oct 9, 2007 | 01:57 PM
01V10's Avatar
01V10
Thanks guys, excuse my ignorance but which 90 degree elbow? Off of the MAF?
Old Oct 9, 2007 | 02:01 PM
dkf's Avatar
dkf
I think some one has a picture of the elbow they could post.
I never had to deal with any YET.
Old Oct 9, 2007 | 02:21 PM
Antelope V-10's Avatar
Antelope V-10
I believe it is on the passenger side of the throttle body.
Old Oct 9, 2007 | 04:02 PM
Carpainter29's Avatar
Carpainter29
An 01 doesnt have that pesky elbow. You probably got too much oil on the k&n, making the maf dirty.
Old Oct 9, 2007 | 04:42 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Wanna bet? Mine does
Old Oct 10, 2007 | 07:25 AM
Fredvon4's Avatar
Fredvon4
My 2001 2v V10 had the rubber elbow too!
Old Oct 10, 2007 | 11:42 AM
Dupper's Avatar
Dupper
Ok, so I just bought a used truck. My first Ford, switched from Dodge 1500 CrewCab 4.7 4.2 20" wheels 3.92 gears, to a F350 CrewCab 4x4 V10 18" wheels with 4.10 gears. It has 41000 miles. How often do you clean he MAF sensor and what other V10 maint tips can you give.
Old Oct 10, 2007 | 12:24 PM
Fredvon4's Avatar
Fredvon4
Dupper
Welcome to FTE and the V10 forum the original home of BSEG
Start your own "thread" and let us know what year and some more info on you and what your intended usage of the truck is
This forum specifically is for the motor--- but there are a lot of us willing to expand to all things power-train and maintenance related.
Again welcome but don't "piggy back".... we get side tracked on your question and the fellow above gets lost in the multiple questions
Old Oct 10, 2007 | 07:35 PM
900rr's Avatar
900rr
i had a problem close to this and my problem was that after i cleaned the maf the connector on the bottom of the housing were the wires and the connector goes into had fallen out so there was an air leak before the throttle body may help you in solving your problem good luck
AndeyHall
Jul 6, 2011 09:32 AM
shawn202003
2004 - 2008 F150
Jun 21, 2011 10:27 PM
Brad2296
39
Nov 11, 2010 06:32 AM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
greenexplorer
Jan 14, 2005 03:24 PM
