Modular V10 (6.8l)
I saw it before in here
Old 10-08-2007, 06:47 PM
01V10's Avatar
01V10
01V10 is offline
Hey guys,
I saw a thread like this before and I apologize for duplicating but I can not find it anymore. I ran some all fuel system cleaner through my truck (2001) and cleaned the K&N along with shooting some MAF cleaner on the MAF. Here is where i saw this before. My truck now sounds like it has a big cam in it when idling (honestly sounds pretty cool with all the exhaust work I have done) and the SES light is on. I took it down to Auto Zone and had them read the code it came up as the MAF or vacuum hose leak, I think i remeber something about left bank lean as well. I will have them pull the code again and I will post it tomorrow. They cleared the code for me and after a day it has come back on. Now it doesn't have big the lopey sound to it at idle but it does idle high now and the revs don't fall as quick as before when in Drive. Like I said I know I saw a simlar post to this but I can't find it anymore. You guys have been helpful in the past and looking for help again. Thanks in advance.
Old 10-09-2007, 07:53 AM
SLE's Avatar
SLE
SLE is offline
Sounds like the ever so commen little 90* elbow that cracks out. easy and cheap to change. good luck.
Old 10-09-2007, 08:38 AM
jonrjen's Avatar
jonrjen
jonrjen is offline
Could it be you over oiled the KN and the MAF is getting oil on it as the air is sucked through the filter, past the MAF on its way to the intake? Just a thought of a common mistake with the reusable filters.
Old 10-09-2007, 09:33 AM
dkf's Avatar
dkf
dkf is offline
I ALWAYS take my MAF sensor completely off the intake for cleaning. There are several wires that need many direct shots with the cleaner to clean them properly. I use CRC MAF cleaner.
The MAF is probably not your problem though.
As SLE said I would check the elbow.
Old 10-09-2007, 01:57 PM
01V10's Avatar
01V10
01V10 is offline
Thanks guys, excuse my ignorance but which 90 degree elbow? Off of the MAF?
Old 10-09-2007, 02:01 PM
dkf's Avatar
dkf
dkf is offline
I think some one has a picture of the elbow they could post.
I never had to deal with any YET.
Old 10-09-2007, 02:21 PM
Antelope V-10's Avatar
Antelope V-10
Antelope V-10 is offline
I believe it is on the passenger side of the throttle body.
Old 10-09-2007, 04:02 PM
Carpainter29's Avatar
Carpainter29
Carpainter29 is offline
An 01 doesnt have that pesky elbow. You probably got too much oil on the k&n, making the maf dirty.
Old 10-09-2007, 04:42 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Wanna bet? Mine does
Old 10-10-2007, 07:25 AM
Fredvon4's Avatar
Fredvon4
Fredvon4 is offline
My 2001 2v V10 had the rubber elbow too!
Old 10-10-2007, 11:42 AM
Dupper's Avatar
Dupper
Dupper is offline
Ok, so I just bought a used truck. My first Ford, switched from Dodge 1500 CrewCab 4.7 4.2 20" wheels 3.92 gears, to a F350 CrewCab 4x4 V10 18" wheels with 4.10 gears. It has 41000 miles. How often do you clean he MAF sensor and what other V10 maint tips can you give.
Old 10-10-2007, 12:24 PM
Fredvon4's Avatar
Fredvon4
Fredvon4 is offline
Dupper
Welcome to FTE and the V10 forum the original home of BSEG
Start your own "thread" and let us know what year and some more info on you and what your intended usage of the truck is
This forum specifically is for the motor--- but there are a lot of us willing to expand to all things power-train and maintenance related.
Again welcome but don't "piggy back".... we get side tracked on your question and the fellow above gets lost in the multiple questions
Old 10-10-2007, 07:35 PM
900rr's Avatar
900rr
900rr is offline
i had a problem close to this and my problem was that after i cleaned the maf the connector on the bottom of the housing were the wires and the connector goes into had fallen out so there was an air leak before the throttle body may help you in solving your problem good luck
AndeyHall
07-06-2011 09:32 AM
shawn202003
2004 - 2008 F150
06-21-2011 10:27 PM
Brad2296
39
11-11-2010 06:32 AM
jcstratt
1997 - 2003 F150
01-31-2006 11:28 PM
greenexplorer
01-14-2005 03:24 PM
Quick Reply: I saw it before in here
