MAF sensor code P0102 and NO power at all...
My truck has been getting the code P0102 ever since my truck broke down a while back (Novemberish of 2010). Shop replaced the PCM thinking my programmer had "fried" it and that did fix the truck but never got rid of that one code. Truck broke down again about a month and a half ago and they installed a new PCM along with a HPOP and when I got it back this time, it ran really sluggish and the P0102 code was still there. The PCM they replaced the truck with was running extremely high boost and it had 0 power. So one day for the hell of it, I put my original computer back in that I had saved and all issues went away and the truck ran awesome. Then a few days ago I went to crank it up after it had sat all night and it sounded very different once it fired, and the boost has been runing normal, but I can tell that it's dumping every bit builds out of the air box (does the turbo fart every time I let off the throttle, no matter how gradual I do it). After running down a few other possible causes, I've gotten it to where it throws absolutely no code except for the "P0102 - MAF sensor curcuit low input" code. Here's some info that might help:
MAF pin #1 --> PCM pin #33
MAF pin #2 --> 12V Power
MAF pin #3 --> Ground
MAF pin #4 --> PCM pin #21
MAF pin #5 --> PCM pin #42
MAF pin #6 --> PCM pin #43
MAF pin #1 --> Signal return
MAF pin #4 --> Mass Air Flow (MAF) sensor (12B579), signal, return
MAF pin #5 --> Mass Air Flow (MAF) sensor (12B579), signal
MAF pin #6 --> Intake air temperature sensor, signal
Images of these schematics can be found on page 3 of the original thread that will be posted below.
So basically it's coming down to 1 main question...Does the symptoms I have described even sound like something the MAF sensor not reading can cause? I believe so based on what the other guys have told me, but I figure there's no such thing as too many (reputable) opinions.
Is there anyone else who knows, based on the information given and the information available on the old thread where I should focus my search? My voltage readings at idle are posted I think on page 8 of the old thread, or maybe page 7.
The link is https://www.ford-trucks.com/forums/1...-symptoms.html
Thanks for any addition help, and hopefuly Blade35, dchamberlain, and npccpartsman, and any other former supporters can find their way over here.
you need to look into circuit 361. we have had more the one issue with that circuit. check near the splice.
load test each and every circuit on the maf using a high beam lamp.
check each circuit for shorts to power, shorts to ground. and shorted to other wires on that system.
issues comming from v.ref, sig return or 12v on 361 can cause a buch of random problems and this is one case were 2 trucks may not act alike.
or
take it back to Bill.
or
Is this something you made up out of a headlight
do you just ground the headlight and pull the load +pos thru the wire your trying to test off the battery thru the wire in ?? to headlamp
I have covered this a bunch..
but here we go.
use a high beam lamp, one end goes to ground and use the circuit that you need to test to go to B+. its simple and it works. just have to know how to isolate a circuit.
