rebuilt np435 no neutral?
Old Sep 17, 2007 | 10:10 AM
skonnie-mark's Avatar
skonnie-mark
I rebuilt my np435 and now it's always engaged - even if the stick is in neutral position the transmission is engaged somehow - the driveshaft spins when I try to start the motor.
Any ideas what I messed up?
Thanks!
Old Sep 17, 2007 | 10:41 AM
stuart1's Avatar
stuart1
You missed the shift gate with the stick.
Old Sep 17, 2007 | 12:56 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Sounds like you missed first gear with the shifter fork, istalled top in truck with the shafts angled down at the rear?
Or do you have all three gates in line before installing the shift lever?
This is an easy fix, remove the lever and look inside, use a large clean screwdriver and align the gates. This best done with a back wheel off the ground and soneone rock the driveshaft to unload the tranny gears.
The missed fork in first gear involves pulling the shifter top.
I have installed a couple new 435 shifter tops over the years that had too short of interlock rods between the ***** that detent into the rails causing engagement of two gears at once. This would allow for reverse or lockup with two gears at once. Another manufacture screwup that's easy to fix with a longer rod.
pbStriker38
21
Oct 15, 2006 11:33 PM
74fordtruck
Offroad & 4x4
Oct 3, 2006 05:15 AM
Nod
Sep 7, 2004 02:22 AM
broncorule
1978 - 1996 Big Bronco
Jul 18, 2003 10:07 AM
gilster00
Nov 29, 2002 12:06 PM
