stick shift question
Old Sep 17, 2007 | 01:22 PM
97squarebody's Avatar
97squarebody
Hello all;
I have a 97 250HD 4x4 with a 460 and a 5-speed manual in it. I'm not positive what it is. The question that I have involves towing with this gear box. When I am pulling a 5th wheel (10,000 lb estimated) should I be in forth or fifth gear. Gennerally it pulls fine in either assuming there are no hills or high headwinds.
I have heard both that you are not supposed to tow in high gear and that its fine if the motor pulls well in high gear.
What is your thoughts? Why?
Thanks for the help.
Old Sep 17, 2007 | 01:28 PM
97squarebody
Opps, my bad.
Last edited by 97squarebody; Sep 17, 2007 at 01:33 PM. Reason: Not needed, Changed post
Old Sep 17, 2007 | 01:33 PM
75F350's Avatar
75F350
Not too sure how the gear selection in the transmission would have any affects on the t-case. Should not have any negative affects on it. The case simply has a 1:1 output so it would not know the difference.
I also believe you have an aluminum Borg Warner case, and not a cast iron New Process.
Old Sep 17, 2007 | 01:48 PM
97squarebody
Hello all;
Please excuse the screw up in my previous post. I believe the t-case is a NP205, the Transmission, I believe, is a ZF. My questions are based on gear selection in the transmission. I have edited the original post.
Old Sep 17, 2007 | 01:49 PM
85e150's Avatar
85e150
Your trans is probably a ZF.
The owner's manual usually says not to tow in OD as OD tends to be weaker in many trans. Do you still have the little shift guide on the visor? Mine says not to tow in od, but my OD is the weakling 4 speed unit.
Trans id site:
http://www.motivegear.com/tech_info/...nny_guide.html
ZF almost all the way down.
Unless the sticker says otherwise, I'd tow in OD as long as it's not a "lugging" heavy throttle situation.
