Advice on installing brake lines 48 F2
I usually buy straight pre-fab lengths and when needed, cut them to length and re-flare one end to suit me. They aren't expensive and if you screw them up, it isn't the end of the world.
With Steel line they must be "Double Flared". I recommend you "Google" what you can to get smart about this. Let's face it, these are Brake lines. No mistakes are acceptable.
You need a good tube cutter, files to dress your cuts, a Flaring tool and in my opinion, a variety of tube bending tools. Each has it's use in certain applications.
You will notice that most all lines have extra length or circular bends, especially around Master Cylinders. This extra length allows for some flex so lines don't work harden and crack or loosen from vibration. Be sure to include some slack.
Buy some extra line for practice. Flaring and bending is not easy at first. You can invest a lot of time in a line and then screw up the bend or flare at the end and it's scrap. It will happen. Just part of the learning experience.
I recommend making some bend samples at various angles so you can pre-determine lengths you need when you get down to the final few bends.
You can never have enough frame clamps or line to line clamps either.
Hope this is helpful.
if you decide to do your own.. this article might help you
plumbing disc brakes
Eman gave you some good info. It's not that hard with some practice with the flaring tool and bender. DON'T buy cheap tools here... they will only cause frustration from poor quality BUT in their defense, they will break something really expensive when thrown across the shop. Eastman makes a good flaring tool as does RIGID. I'd recommend a good mandrel type bender (see article). I really enjoyed doing mine.. now don't think I did it all perfectly the first time. I probably bent the lines from the master cylinder on the firewall down to the frame at least 4 or 5 times, till I got all the bends like I wanted them... and you'll leave off a couple of fittings and realize it just after you make that 90 degree bend
but that is part of it too...Eman mentioned stainless. Several issues here... #1 it's expensive #2 they don't use 45 degree double flares so all your fittings have to match the 37 degree single flares you use on SS. #3 you use a different flaring tool #4 it's harder to deal with then plain steel. #5 it's pretty with buffed up and coated, but if your truck isn't over mirrors at the WoW, who's gonna see it ??
#6 It's expensive.
You can buy the steel lines in rolls or pre measured lengths at good auto parts stores or from hot rod shops and both will make a very nice looking system for you...
As Eman said...this is no place to cut cost corners.. spend the cash and the right amount of time on this segment of the truck !!! do it yourself !! and have fun, plus you learn something new that you can impress your rodding buddies with and add something personally done to your ride... worth much more than a receipt from inline tube, inc. to me
later
John
This is one area I did early in my rebuild and I am thinking of redoing mine; I'm not happy with the look from the MC down to the frame. I used the power boost from a 1999 Explorer; it is tight between my inner fenders and the brake booster mounted on the firewall; my flex loops are very close to the inner fender.
Does anyone know of a supplier of 1/4" fittings that have 90 degree threaded and flare out ?
1st, on your way to your friendly neighborhood parts store don't neglect the friendly neighborhood frosty beverage distributor (you will need a good supply of frosty beverages)
2nd, when you go buy the steel lines buy some extras. This will be real important when you make the obligatory screw ups and ruin several pieces of line just scant moments after the parts stores have closed for the day
3rd, since you thought ahead and now are the proud owner of extra line, start out by fabricating and bending up several complicated sections, carefully cut the line, follow all the directions to your double flaring tools, make the required flare, step back and start patting yoruself on the back while admiring your handiwork (OK, here is the important bit).......... .............look over on the edge of the bench....thats right, right over there.... .....is that??.... .....no, certainly not!.... ...it couldn't be.......... ....*#&%@# (insert your favorite expletives here--enough to make Yosemite Sam blush)........
...sure enough, sitting right there in plain site is the nut that should have been on the line BEFORE the flaring process.
4th, repeat above steps several times and at intemittant intervals in the whole brake line fabrication process.
5th, drop tools in disgust, imbibe a frosty beverage while marveling at just how many silly mistakes can be made while trying to make a simple steel line
Finally, (here's another important bit) Laugh at yourself! grab another section of line and get back to work.
Good luck, its actually fairly easy and can be quite rewarding (once its all said and done)
Bobby
So your choice. Plus, trying to figure out how to run the brake lines is you choice. If you have a firewall mounted master cylinder yours will be different, and if you changed the transmission and are not using the stock crossmember, the prefab lines might not work either.
