Any advice on painting my '38 Pickup?
1) Not sure if I should paint it in pieces and reassemble, or all togethor.
2) What about painting the welting? Do it serperately or not?
3) Where to get good smooth welting?
Mike, thanks. I was thinking in pieces as well. But if the welt is not painted then it will not match the custom color I am using and then that won't look as well. Sound like whining to you...? It is. This issue has bugged me for several months now! So, why not paint the welt?
Many thanks again, DM
I've never seen painted welt that didn't crack(the paint) over time.
There may be something out there now (like a modifier used on fiberglass or plastic bumpers) that you could use to pre-paint it before installing it...might want to check with a custom paint shop.
Paint it one piece at a time, like I did. I like the fact that there is zero overspray on unwanted parts. I have heard that a paint additive called "Flex" can be mixed with the custom paint and sprayed on the welting. I would recommend spraying a test piece of welting, and after it is cured, put it through its paces. It seems if you were to take a piece of welting to your local paint shop and ask, they could help.
Post some pics in your gallery, I've helping a friend with the final assembly of his highly modified '38 pick up, and I'm sure he would like to see it
Bob.
Thanks for the kind words. No links for the '32 yet. The wife says I can't work on it yet....I've got to finish the '34 (it's torn apart for a heat & AC install)
Bob
Sounds like my dad. He's not allowed to work on his 32 Five Window until the 32 Woodie is finished. My dad always takes the car completely apart to paint them, but he restores them to mint original.
it depends on what you are trying to acomplish as to whether you paint in in one piece or as one car. I have done them both ways, and always seem to end up repainting the outside of the auto again after I have is all assembled. I have tried everything to keep from getting the little wrench knicks, and the like from the new paint as i'm assembling. so the way I do it is to dissassemble, and then strip and repair every peice, then paint as I reassemble, esspecially if I am changing colors on the car. then I assemble, in pieces,sand all the knicks, and then very carefully mask. don't be afraid to use miles of tape, litos of paper, a utility knife, and several hours. then I shoot another coat of paint to that everything matchs, all the knicks are covered. Then sand, and polish.
Let me know how it turn out.
Howard
46-ford-tonner.blogspot.com
