Por 15 Questions
Old Mar 11, 2007 | 03:22 PM
surfer55's Avatar
surfer55
Por 15 Questions
Hey, I am going to paint my frame with Por 15(unless somthing better comes up).
I was wondering how well it does on a sandblasted frame?
My frame still has some rust right now but I would like to blast it just to get the rusty spots that I couldn't get with a wire brush.
If you guys know anything, or have tips or other ideas,
I would love to hear em'.
Surfer
Old Mar 11, 2007 | 09:55 PM
pbr man's Avatar
pbr man
You should look into Rust Bullet. Minimal surface prep and easy to apply. I have used it with excellent results.
http://rustbullet.com/Products/Automotive/Automotive.htm
Old Mar 11, 2007 | 09:58 PM
bucks77ford's Avatar
bucks77ford
If your going to sandblast the frame, than POR 15 will not have any problem holding up or sticking to the frame. Sandblasting is usually always recommended as the ideal starting point, even though it can be painted directly over rust. I used Chassis Saver by Magnet paints and am real happy so far with the way it worked. Rust Bullet claims to be better than POR 15.
Your going to find different claims by different products no matter what, so whatever you use is up to you. I've heard good things from most products along with bad things. I have heard the best things from Rust Bullet and Rust encapsulator products. I liked Chassis Saver so far, but than again my frame hasn't been on the road yet to see actual results...
Not to say POR 15 is a inferior product, because I have not used it, I'm sure it does a great job. I just thought It was real expensive compared to some of the other products I have found that claim they do the same thing is why I went with different product. I was going to use POR 15 at first. Anyway, bottom line......a blasted frame is ideal.
Old Mar 12, 2007 | 03:06 PM
surfer55's Avatar
surfer55
Thanks Guys!
I think I'll look into those.
Old Mar 12, 2007 | 05:31 PM
mfraley65's Avatar
mfraley65
Used por-15 last year on my 51 frame and it was on the ground until this past saturday when i put it on blocks and was actually surprised that the rust had not come back through after laying that long. Por-15 is pretty good, imo. Have not tried rust bullet, yet.
Old Mar 13, 2007 | 03:02 PM
surfer55's Avatar
surfer55
Thumbs up
Thanks!
I think I am going to try it out and see, it has alot going for it.
P.S. I will let you guys know how it go's.
Surfer
droppedf100
Feb 16, 2012 11:54 PM
82airborne82
30
May 20, 2010 06:03 PM
Flaflathead
Dec 15, 2004 02:14 PM
surfer8400
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 17, 2004 10:02 AM
hillbillyk
Paint & Bodywork
Aug 27, 2003 04:14 AM
