enamel paint too soft?
Old Feb 26, 2007 | 08:25 PM
bbgot's Avatar
bbgot
I am doing a total repaint on a 78 bronco. I am using CNH Case tractor enamel paint with a compatible CNH primer. Even after two weeks of drying time, the paint will scratch easily with your fingernail. This is my first try at automotive paint work but I thought that tractor paint would be a little tougher than this. Any help or suggestions would be appreciated.
Old Feb 26, 2007 | 08:41 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
Did you use the right amount of hardener ?
That would be the only thing I would think that might cause that, or it's really cold where you did the sprayout.
Old Feb 27, 2007 | 12:52 AM
edgescreambeauty's Avatar
edgescreambeauty
Yeah, the recent CNH paint is a little soft. I've painted a few tractors and lawnmowers with the CNH stuff. I've never tried hardener but plan to this summer to see if there is a difference. Otherwise, I've just been careful around the paint. I painted my rear bumper with the CNH silver last summer. It was pretty soft but eventually hardened. Then I backed into a piece of machinery and scuffed all my new paint anyway. Oh well, I'll get to play around with the painting more this summer.
Old Feb 27, 2007 | 08:21 AM
bbgot's Avatar
bbgot
when I bought the paint I told the salesman that I wanted everything that I would need to do a total repaint. He gave me the primer, reducer, and enamel paint. He didn't say anything about using a hardener but I'll go back today and see if there is a hardener for my type of paint.
Old Feb 28, 2007 | 07:40 AM
teds74ford's Avatar
teds74ford
I have never heard of that stuff, but it sounds like my results with rustoleum. The stuff is slow curing, and will take at least a month to harden, and probably 6 to be truly cured.
Old Feb 28, 2007 | 01:00 PM
bbgot's Avatar
bbgot
that sounds about right. I went back to where I bought the paint and asked about using a hardener. I was told that the paint I am using does not require a harnener and would take almost a month to fully cure if its just air-drying.
Old Mar 2, 2007 | 12:34 AM
76fordfan's Avatar
76fordfan
I tried that on my truck and after it finaly hardened it started to rust because of the moisture it held in Just my luck
Old Mar 7, 2007 | 06:42 PM
hillbilly1025's Avatar
hillbilly1025
i'm not sure what ya'll mean by cnh(brand i assume) but the local "tractor supply" stores sell their brand tractor paint and recomend a hardener. i believe they advertise it as an "automotive quality" paint. i'd go back to the store and see for yuorself if there is a hardener and not talk to the salesman
Old Mar 13, 2007 | 05:32 PM
Lost Pride's Avatar
Lost Pride
all enamel paints take 15-30 days to cure 100%
Redneckfordf2502002
Paint & Bodywork
Aug 4, 2016 02:39 PM
filthy6
Jun 4, 2016 12:44 PM
popbreed
Paint & Bodywork
Feb 21, 2010 07:02 PM
aerocolorado
Paint & Bodywork
Oct 16, 2003 10:48 AM
